![]() | Home > General > Top Up |
| codfather Member Since: 13 Feb 2010 Location: ayr Posts: 1171
I checked with the service dept what oil they put in, and it was shell helix, so have been putting that in ever since!
| iknight167 Member Since: 11 Sep 2009 Location: STAFFS Posts: 11
Many thanks. |
| Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796
Is that common for it to lose/usethat much oil in such a short space of time/mileage? ON THE WAY: BMW F21 M140i
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159
Good question. Oil half way up the stick would be about right. I'd monitor it on a weekly basis and see if it drops at all - which it really shouldn't on a new car.
| SVR575 Member Since: 16 Apr 2008 Location: uk & Europe Posts: 1828
That Castrol Oil is so hard to find that its almost unbelievable! Why? SVR 2018 in Santorini Black. |
| oldcro Member Since: 25 Aug 2010 Location: Shetland Posts: 359
Was the oil still hot from a run or cold? Check after 15 to 20 minutes after a run not say next morning. Synthetic oils quite a bit so checking level with a cold engine could result in overfilling which is worse than being a bit low.
Later mdl RRS , oil can only be checked about 15mins after use. SVR 2018 in Santorini Black. |
Good point TDV8HST, I'd forgotten about that. |
| All times are GMT |
