Home > General > Top Up
iknight167
Top Up
Evening everyone,
Checked my oil today, it's a MY12 Sport and it was showing just over halfway after 2.5k miles. According to the handbook Land Rover "recommends" Castrol oils, but I cannot find a Castrol oil 5w-30 with WSS-M2C934-B on the side. The oils stating that specification seem to be Shell (Helix).
What does everyone use for a top up or is it O.K. to use any 5w-30? With past Audis most manufactures show the VW specification on the side.
Post #326518 Fri Dec 30 2011 6:43pm
codfather
Scotland 2010 Range Rover Sport 3.0 TDV6 SE Santorini Black
I checked with the service dept what oil they put in, and it was shell helix, so have been putting that in ever since!
As long as it is same viscosity and type( semi synthetic I think) it will be fine
Dave MY10 TDV6 SE (debadged Wink ), Santorini Black, Flappy paddles, Privacy Glass, 20" Stormers, Mudflaps!
Gone: a comprehensive list of imprezas and a Merc ML AMG
Post #326521 Fri Dec 30 2011 7:16pm
iknight167
Many thanks.
Post #326525 Fri Dec 30 2011 8:00pm
Is that common for it to lose/usethat much oil in such a short space of time/mileage? ON THE WAY: BMW F21 M140i
Post #326539 Fri Dec 30 2011 11:31pm
Good question. Oil half way up the stick would be about right. I'd monitor it on a weekly basis and see if it drops at all - which it really shouldn't on a new car.
It doesn't need to be at the top of the stick. Mid way is fine. 2012 SDV6 - it's missing a couple of cylinders
Post #326541 Sat Dec 31 2011 12:43am
SVR575
That Castrol Oil is so hard to find that its almost unbelievable! Why? SVR 2018 in Santorini Black.
Post #326566 Sat Dec 31 2011 4:36pm
oldcro
Scotland
Was the oil still hot from a run or cold? Check after 15 to 20 minutes after a run not say next morning. Synthetic oils quite a bit so checking level with a cold engine could result in overfilling which is worse than being a bit low.
Helix is the name for a range of oils, so make sure you buy the correct spec of low SAPS oil i.e. this one
http://www.opieoils.co.uk/p-68975-shell-he...e-oil.aspx
Post #326577 Sat Dec 31 2011 6:41pm
SVR575
Later mdl RRS , oil can only be checked about 15mins after use. SVR 2018 in Santorini Black.
Post #326582 Sat Dec 31 2011 7:49pm
oldcro
Scotland
Good point TDV8HST, I'd forgotten about that.
Post #326590 Sun Jan 01 2012 12:41am
