![]() | Home > General > wierd thing going on with traction control??? |
| x5pea Member Since: 03 May 2007 Location: Lanarkshire Posts: 2097
Sounds like a fault sensor had a similar issue with my FFRR. Have a look at the 4x4 info on the screen it will show all 4 wheels with a green line above each wheels , that's the height sensors. if any of the sensors have an issue They will flash green, I'd bet that one of them will be red.
| felstmiester Member Since: 26 Apr 2011 Location: hertfordshire Posts: 203
Ok. On the screen it shows all 4 wheels with a short little red line behind all 4 wheels then 1 long green line that seems to only be above the front wheels. Nothing is flashing on the screen but like I say only the one green line. |
Strange the air system is only a 2 way system, Which means the 2 front wheels are connected via the same valve and the same with the 2 rears. If one sensor goes the rear then both sides will be affected as the system cant raise or lower one corner without doing the same to the other side.
Ps
Thanks. I'll keep you posted on the problem.
Took it out this afternoon andits seemed to have righted itself. |
| Vadim Member Since: 20 Apr 2010 Location: London Posts: 855
Great to hear! |
happy days |
| All times are GMT |
