| RRSPORT.CO.UK | ||
|  | Home > General > wierd thing going on with traction control??? |
| x5pea Member Since: 03 May 2007 Location: Lanarkshire Posts: 2097      | Sounds like a fault sensor had a similar issue with my FFRR. Have a look at the 4x4 info on the screen it will show all 4 wheels with a green line above each wheels , that's the height sensors.  if any of the sensors have an issue They will flash green, I'd bet that one of them will be red.
|  Thu Dec 29 2011 11:29am |
| felstmiester Member Since: 26 Apr 2011 Location: hertfordshire Posts: 203      | Ok. On the screen it shows all 4 wheels with a short little red line behind all 4 wheels then 1 long green line that seems to only be above the front wheels. Nothing is flashing on the screen but like I say only the one green line. | ||
|  Thu Dec 29 2011 11:44am |
| x5pea Member Since: 03 May 2007 Location: Lanarkshire Posts: 2097      | Strange the air system is only a 2 way system,  Which means the 2 front wheels are connected via the same valve and the same with the 2 rears. If one sensor goes the rear then both sides will be affected as the system cant raise or lower one corner without doing the same to the other side.
|  Thu Dec 29 2011 12:04pm |
| x5pea Member Since: 03 May 2007 Location: Lanarkshire Posts: 2097      | Ps
|  Thu Dec 29 2011 12:05pm |
| felstmiester Member Since: 26 Apr 2011 Location: hertfordshire Posts: 203      | Thanks. I'll keep you posted on the problem.
|  Thu Dec 29 2011 12:09pm |
| felstmiester Member Since: 26 Apr 2011 Location: hertfordshire Posts: 203      | Took it out this afternoon andits seemed to have righted itself.   | ||
|  Fri Dec 30 2011 6:46pm |
| Vadim Member Since: 20 Apr 2010 Location: London Posts: 855      | Great to hear!  | ||
|  Fri Dec 30 2011 8:21pm |
 happy days   | ||
|  Fri Dec 30 2011 9:30pm |
| Posting Rules
