![]() | Home > General > Cruise Control |
codfather Member Since: 13 Feb 2010 Location: ayr Posts: 1171 ![]() ![]() ![]() |
Thats strange, when I first started reading your post , I was assuming that maybe you has an older car, but I see yours is bang up to date! My 2010 looses/gains only about 1mph ( say 2kph)
JONRRS Member Since: 10 Jan 2011 Location: Sydney Posts: 51 ![]() ![]() ![]() |
Thanks Dave,
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8879 ![]() ![]() ![]() |
My 2007 is fine at holding the set speed. 2012 SDV6 - it's missing a couple of cylinders
x5pea Member Since: 03 May 2007 Location: Lanarkshire Posts: 2097 ![]() ![]() ![]() |
yeah each the above comments mine is pretty mich bang on, Ive had a few VW's also and i wouldnt say the cruise was any better or worse on the LR |
rrsboy Member Since: 06 Jan 2009 Location: UK Posts: 1391 ![]() ![]() |
mine brakes going downhill, stays +/1 1mph ============
ronniet101 Member Since: 10 Mar 2007 Location: West Country Posts: 298 ![]() ![]() ![]() |
dont know if it actually brakes...without seeing the detailed spec cant say how it behaves..but seems to allow increase in speed of 10% of speed demanded when going downhill before it changes gear down and reduces fuel demand |
Definitely sounds like mine is a bit off.
Just an update on this.
bootz Member Since: 14 Oct 2011 Location: England Posts: 86 ![]() ![]() |
The 2 RRSS's I had with adaptive cruise control were much better at maintaining accurate set speeds than those with the standard cruise control option.
The Speed Control System in your vehicle is a very sophisticated system that is integrated with the engine management system and uses fuelling intervention to automatically maintain a set vehicle speed. Once engaged, the system can also be used to accelerate the vehicle without using the accelerator pedal. The speed control system also uses inputs from the brake pedal switch, the APP (accelerator pedal position) sensor, the ECM (engine control module) and the ABS (anti-lock brake system) control module. During speed control operation, the ECM controls vehicle speed by adjusting fuel injection duration and timing. When the accelerator pedal is pressed with speed control active, the ECM outputs a calculated throttle angle signal in place of the actual throttle angle signals produced by the APP sensor. The calculated throttle angle is derived from fuel demand. If you have Adaptive Speed Control, this system uses a forward looking radar sensor to scan the road ahead, looking for objects that are moving at a different rate to itself. When a target is identified the adaptive speed control system will monitor the time gap between it and the target vehicle. When that gap falls below a set driver selected level (4 seconds) the adaptive speed control system will intervene slowing the vehicle by backing off the throttle and/ or applying the brakes, until the correct gap is attained. The adaptive speed control system comprises the following components: Adaptive Speed Control Sensor Adaptive Speed Control module Steering wheel control switches ECM (engine control module) Electric throttle ABS (anti-lock brake system) module and pump This is just a brief explanation of how the system works and it shows how much effort has been put into this system. ![]() ![]() You have good UK engineering there, however, you may want to seek advice from a reputable LR dealer. ![]() 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
Mr H Member Since: 09 Sep 2011 Location: Lincs Posts: 427 ![]() ![]() ![]() |
Bobby how on earth do you know all this stuff ?!? |
I first thought it would be due to extreme conditions in Oz, dust/heat etc, but I would hardly think Sydney is like the outback! Not heard anything from my dealer in cold damp Scotland!! Cheers Dave MY10 TDV6 SE (debadged ![]() Gone: a comprehensive list of imprezas and a Merc ML AMG |
saty Member Since: 17 Aug 2011 Location: Beds Posts: 227 ![]() ![]() ![]() |
My 55 plate non adaptive is also like yours, not as accurate my BMW's I used to have.. |
andman Member Since: 08 Oct 2011 Location: la vella Posts: 1155 ![]() ![]() ![]() |
Just checked on LR website..... Servicing on the RRS 3.0 is every 12 months still or 26k miles whichever comes first.... sounds like right dodgy info your dealer gave you... see link below http://www.landrover.com/gb/en/rr/owners/s...servicing/ |
