Home > Technical > heated washer jets
tigers111
United Kingdom 2006 Range Rover Sport TDV6 HSE Santorini Black
heated washer jets
Hi all just wondering what spec the heated windscreen washer jets where fitted too or was it an optional extra, my 06 rrs hse has heated everything but the washer jets where frozen this morning taking the wife to work, so i either don't have them or they don't work
Post #323964 Mon Dec 05 2011 9:34am
Jimmy_75000
i have them... they works.. and still frozen from time to time.... You should check your screen wash liquid and make a cold weather mix.... Range Rover Vogue ‘17 TDV6
Gone: Range Rover Vogue '11 4.4TDV8, Range Rover Sport ‘59, Range Rover Sport ‘56
Post #323966 Mon Dec 05 2011 10:17am
Endjin
Scotland
You will have the heated water jets, but to be honest they are not any good at keeping the nozzles clear of icing when driving in low temperatures if you have a diluted screenwash mix. At this time of year it's best to put screenwash straight from the bottle without adding additional water. If you read the instructions on the screenwash you'll find most recommend this anyway. By doing this i've never had it freeze either at the nozzles or in the cars bottle & pipes. It might seem expensive but it's a lot cheaper than having burst pipes/water bottle in the car. 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black
2013 Evoque 5 Door Pure Tech SD4 - Orkney Grey with Panoramic Roof (Mrs E's new baby)
GONE - RRS - 3.0 TDV6 HSE - Santorini (2010)
GONE - RRS - 2.7 TDV6 HSE - Java Black (2007)
GONE - Porsche Boxster S - 3.2 - Black
Post #323971 Mon Dec 05 2011 10:45am
Steuart64
Scotland 2011 Range Rover Sport 3.0 TDV6 Autobiography Orkney Grey
First good frost this morning and first chance to see if mine were repaired correctly last March. Temp was -5C and my mix is for -10C.
No tell tale thawing of ice on nozzles or bonnet like I had on my A4 and FL2. Tried the washers - no spray.
Understand wind chill etc but I would have expected mine to work from standstill with the mix/heated nozzles.
Another visit to dealer I think! Now - MY11 RRS Autobiography TDV6, Orkney gray, tints, steps, daylight running lamps and allllll the toys!!!
Ex- RRS HSE TDV6 07 Java Black, bi xenon, corner lights, side steps, tints, cool box, smoke side repeats, chrome "sport" boot sill
Ex - Audi A4 Cab 3.0TDi Quattro
Ex - Freelander2 SE TD4
Ex - CRV Auto
Post #323990 Mon Dec 05 2011 1:24pm
dazzagt
United Kingdom 2006 Range Rover Sport Supercharged HST Java Black
If any of you are travelling through germany / belgium / france, the bigger fuel stations sell much better screen wash, normally use the stuff from Aral fuel stations in germany, goes down to -50 ( not that I've tested it ) but last couple of years when we've had -5/7 temps and big hard frosts in the early morning they have worked perfectly, cleared the ice and once over the screen and wipers all everything OK, when the usual UK stuff has frozen in the pipes, as been said mix is crucial too Thumbs Up RRS S/C, Factory Fitted Full HST kit, 22" Overfinch SS, Carbon Vents & Grill .. - FOR SALE - PM me for details
997 GT3 - X6 35d
Post #323998 Mon Dec 05 2011 2:03pm
tigers111
I Know about the quantities of mixing screen wash for winter, I have it mixed well now but i thought that the heated washer jets would have been more successful
Post #324029 Mon Dec 05 2011 5:59pm
bootz
I had the washer nozzles freeze up last year in below zero temps on the motorway, and it sometimes also happened after overnight low temps. Disapointing tbh, and the screen wash in the bottle was 100% concentrate and good for -10 allegedly.
I was looking at a pre-heat system ('Heatshot') which might be a solution - has anyone fitted one?
Post #324038 Mon Dec 05 2011 7:55pm
codfather
Scotland 2010 Range Rover Sport 3.0 TDV6 SE Santorini Black
I suspect there is a more scientific reason for the heated jets to freeze up, in the reservoir bottle, the liquid is a fair volume and won't freeze, but after you use the washer jets there are tiny droplets left around the nozzle , and as it exposed, any ethanol in the mix will probably evaporate leaving a weakened solution which will then freeze.
Just my thoughts, any physics type people out there who can back me up/ shoot me down??
Dave MY10 TDV6 SE (debadged Wink ), Santorini Black, Flappy paddles, Privacy Glass, 20" Stormers, Mudflaps!
Gone: a comprehensive list of imprezas and a Merc ML AMG
Post #324066 Mon Dec 05 2011 11:10pm
Seems like a reasonable idea Dave... 2012 SDV6 - it's missing a couple of cylinders
Post #324071 Tue Dec 06 2011 1:10am
bootz
http://heatshot.co.uk/
a possible solution??
Post #324107 Tue Dec 06 2011 11:56am
leedsunited
United Kingdom 2008 Range Rover Sport TDV6 HSE Java Black
That is excellent and only 10 minutes to fit Shocked
Post #325305 Thu Dec 15 2011 10:09pm
panda
Looks good.But!!
Only showed live anD earth connections, does this mean its on all the time heating fluid??
Would the fluid from heater to nozzles still freeze once used and in freezing conditions??
Couldn't find much info on video's.
Post #325330 Fri Dec 16 2011 10:49am
Supacat
I think a -10C mix is a little marginal for this time of year. You need a bigger margin of safety to ensure 100% use. OK we are having a mild winter so far compared to last year. Have you tried buying the neat fluid rather than the pre-mixed? That way you can get to -20C or more and then take a view whether to top your bottle with neat water (based on countryfile week ahead forecast!) or more neat.
Post #325392 Sat Dec 17 2011 9:43am
Supacat
Looks interesting but a couple of points:
    1. 50 amp current draw is not insignificant
    2. It does appear to be permanently live so what is residual current draw. Our cars seem to be prone to low battery warnings and subsequent system failures.
    3. Wonder how long the unit would last when fitted adjacent to the exhaust manifold as they appear to have done on their installation video?
    4. Where would it fit under the bonnet of our car?
    5 Price - £179.99 inc. VAT seems too steep to me
Post #325399 Sat Dec 17 2011 10:29am
