| RRSPORT.CO.UK | ||
|  | Home > Maintenance & Modifications > remaps ?? |
| bootz Member Since: 14 Oct 2011 Location: England Posts: 86    | 30mpg, moi??   | ||
|  Tue Nov 22 2011 8:30pm |
| bootz Member Since: 14 Oct 2011 Location: England Posts: 86    | Thanks for the Sport mode   | ||
|  Tue Nov 22 2011 8:33pm |
| BulletProofBomb Member Since: 12 Jan 2010 Location: Lanarkshire Posts: 164      | Cant believe I've never heard of this till now.  Heres me been sitting in sand mode at the lights all this time.   | ||
|  Wed Nov 23 2011 8:57pm |
| Ady 555 Site Moderator Member Since: 12 Dec 2010 Location: Good old yorkshire Posts: 8738      |
 No he's not, sand mode is supposed to give you the best getaway from a standing start.   | ||
|  Wed Nov 23 2011 9:33pm |
| BulletProofBomb Member Since: 12 Jan 2010 Location: Lanarkshire Posts: 164      | No mate, no joke.  Sand mode apparently is set up so the traction control dosnt kick in when your on loose sand and kill the power to that wheel so as you can get out of the sand with constant motion.
|  Wed Nov 23 2011 10:28pm |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159      | Ok. Sand mode. Might try it once but the first gear in CS mode works very well enough... 2012 SDV6 - it's missing a couple of cylinders
|  Thu Nov 24 2011 12:25am |
| GBUK Member Since: 05 Jul 2011 Location: Trowbridge Posts: 2      | Back to the original question.  Received a Viezu Switch for my TDV8 about a month ago.
|  Wed Nov 30 2011 11:07pm |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159      | Tried the sand mode method. Yeah, works well. Better than CS 1st gear? Not noticeably and it's a lot easier to move the stick around than it is to mess around with the TR dial in my view. Anyway, to each their own  | ||
|  Wed Nov 30 2011 11:58pm |
| BulletProofBomb Member Since: 12 Jan 2010 Location: Lanarkshire Posts: 164      | Been using the command shift mode for a few days now and I think thats better off the mark than the sand mode, may be all in the mind though.  I've also been combining the 2 and just read tonight about left foot braking instead of using the EPB, gonna give that a shot as well.
|  Thu Dec 01 2011 12:12am |
| oxford-boy Member Since: 10 Nov 2011 Location: Oxford Posts: 148      | Remap! You won't regret it.... 2005 Range Rover Sport TDV6 HSE in Artic Frost. 20" 2010 HST Alloys, sidesteps, Hawke tips, plus minor bits and bobs along with a remap. Four spike spiders ready for the Alps again now tucked up in their garage boxes... | ||
|  Thu Dec 01 2011 1:46am |
| ellivas Member Since: 23 Feb 2010 Location: Dewsbury Posts: 58      | [If you use command shift to pull away just pop it into 1st gear and you will see it make a whole lot of difference but then don't forget to either pop it straight back into auto or use your command shift to go up your gears, if you use auto only to get away from a standing start it sets off in 2nd gear hence the slow get away]
|  Thu Dec 01 2011 4:03pm |
|  Thu Dec 01 2011 4:07pm |
| zb Member Since: 31 Dec 2010 Location: CI Posts: 72    | command shift ?! what is that | ||
|  Sat Dec 24 2011 10:56pm |
| Ady 555 Site Moderator Member Since: 12 Dec 2010 Location: Good old yorkshire Posts: 8738      | Put your gear lever to the left it then puts your gearbox into sport mode, then push your gear lever forward and you are now in command shift on your dash where it usually says that you are in D it now says you are in 1 push it again and it goes into 2 and so on, pull the lever back and it drops down the gears    | ||
|  Sun Dec 25 2011 4:33pm |
| Posting Rules
 1st gear tip, I must try it sometime  - only the once mind
 ')  ) for the cost of 1 mpg overall - don't suffer the lag at take off - just need to be careful as the power is awesome.  With 1800kg caravan on the hook it is trully unbelievable!!
