Home > General > Seat fault HELP Needed
cartrimmer
United Kingdom 2010 Range Rover Sport Supercharged Santorini Black
Got an se model, front seats worked absolulety fine, then whilst vacuuming the carpet moved the drivers seat right back and now both seats have stopped working, i have checked all the fuses, i have checked all the wiring and still no movement, although when pressing the swithes to move forwards and back the motor under the seat does jolt, apart from that i can't find why it won't work. Has any one got any suggestions as to what to try??, has any one come accross this problem before. look forward to receiving some comments or answers as frustration has now set in beyond the level of sanity. thanks
Post #312435 Sat Sep 03 2011 4:49pm
sweetafton
England 2011 Range Rover Sport Supercharged Santorini Black
Have you tried locking the car then opening it. Like resetting the whole thing. It's just a thought.
Post #312438 Sat Sep 03 2011 5:33pm
andy r
2008 Range Rover Sport TDV6 S Zambezi Silver
Could have come to the end of its travel ?? Never taken one apart so not sure how they are driven, could try pushing seat forward whilst flicking the switch !? 08 2.7 RRS "S"
Td5 110......very modified
RS 5
Kawasaki ZX12R Censored me, it's quick !
Post #312443 Sat Sep 03 2011 6:50pm
firstinretail
United Kingdom 2005 Range Rover Sport 4.4 V8 Siberian Silver
they are on a screw thread, a threaded bar is fixed and the motor runs up and down, obviously this must be electrical, as the passenger seat isnt working either, double check the fuses.
Post #312444 Sat Sep 03 2011 6:58pm
cartrimmer
tried that doesn't work
Post #312449 Sat Sep 03 2011 8:22pm
cartrimmer
not tried that will try in the morning thanks
Post #312451 Sat Sep 03 2011 8:23pm
cartrimmer
thanks had a good look at that but has stopped working before it reached the end of the thread travel
Post #312452 Sat Sep 03 2011 8:25pm
cartrimmer
also i have changed all the fuses three times and removed the seats to see the only thing i can think of doing now is to by pass the power to the motor and get the position back to driving position.
Post #312453 Sat Sep 03 2011 8:28pm
timcom0
Look under the seat to where the loom connects and see has it dislodged a little, I think the power is daisy chained from one to the other so if first plug in line disconnects affects the other seat, just find the connector pull out and then reconnect securely, i.e. push right home, not sure but solved mine when had similar problem
Post #312465 Sun Sep 04 2011 12:00am
