![]() | Home > General > Seat fault HELP Needed |
| cartrimmer Member Since: 10 Jul 2011 Location: leicester Posts: 16
Got an se model, front seats worked absolulety fine, then whilst vacuuming the carpet moved the drivers seat right back and now both seats have stopped working, i have checked all the fuses, i have checked all the wiring and still no movement, although when pressing the swithes to move forwards and back the motor under the seat does jolt, apart from that i can't find why it won't work. Has any one got any suggestions as to what to try??, has any one come accross this problem before. look forward to receiving some comments or answers as frustration has now set in beyond the level of sanity. thanks |
| sweetafton Member Since: 05 Dec 2009 Location: Weymouth Posts: 961
Have you tried locking the car then opening it. Like resetting the whole thing. It's just a thought. |
| andy r Member Since: 04 Jul 2011 Location: Torbay Posts: 370
Could have come to the end of its travel ?? Never taken one apart so not sure how they are driven, could try pushing seat forward whilst flicking the switch !? 08 2.7 RRS "S"
tried that doesn't work |
not tried that will try in the morning thanks |
thanks had a good look at that but has stopped working before it reached the end of the thread travel |
also i have changed all the fuses three times and removed the seats to see the only thing i can think of doing now is to by pass the power to the motor and get the position back to driving position. |
| timcom0 Member Since: 11 Jul 2009 Location: Sheffield Posts: 235
Look under the seat to where the loom connects and see has it dislodged a little, I think the power is daisy chained from one to the other so if first plug in line disconnects affects the other seat, just find the connector pull out and then reconnect securely, i.e. push right home, not sure but solved mine when had similar problem |
| All times are GMT |
