Home > Technical > Fridge Not Working???
BIG DJ
My fridge doesn't work Big Cry
The light comes on at the switch and I can here the fan going but it's not getting could!
Help any ideas Thumbs Up
Post #309760 Sat Aug 13 2011 7:54pm
airwolf222helicopters
same on mine too light goes blue ,fan noise , same temp , glad im not just the only one
maybe someone has found out the awnser? Banging Head
Post #309798 Sun Aug 14 2011 9:42am
BIG DJ
Couldnt believe it the other day when I got a hot drink out!
Post #309835 Sun Aug 14 2011 5:39pm
firstinretail
United Kingdom 2005 Range Rover Sport 4.4 V8 Siberian Silver
same here, very little tech advice about, me thinks most people just send them in to be fixed Smile
Post #309843 Sun Aug 14 2011 7:11pm
SOMEONE MUST KNOW ?
Post #309846 Sun Aug 14 2011 8:24pm
Bobby
We discussed this here..
http://www.rrsport.co.uk/forum/post186176.html#186176 Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #309849 Sun Aug 14 2011 9:21pm
chris mc
Scotland 2011 Range Rover Sport TDV8 Autobiography Stornoway Grey
Having looked at a picture of one it appears to be a seperate unit from that of the AC system. Do you have the fridge out at the minute?
Post #309850 Sun Aug 14 2011 9:30pm
BIG DJ
Just read the link but unless I'm missing something I can't see what the problem is or a solution
Chris- it's not out at the moment but will be stripping it in the next couple of days to have a look.
Post #309855 Sun Aug 14 2011 10:18pm
oldcro
Scotland
I've had my RRS now for 9 months and this thread has reminded me I have never tried the fridge. Must go fro a run tomorrow with a warm can of coke in the fridge and see what the result is. Embarassed
Post #309856 Sun Aug 14 2011 10:43pm
chris mc
Right having read the link Bobby provided, i'm thinking the most likely problem is a break in the electrical connections of the elements (so to speak), this would explain why the fan would run but no cooling being produced.
I cannot see any mention of control for switching between cooling and heat but given that the application is solely for cooling i don't imagine there being a need for it.
I suggest removing the fridge and testing the points with a meter for continuity and or resistance
Post #309860 Sun Aug 14 2011 11:11pm
NickM
Don't put a warm can in, put a cold one in. It keeps things that are cold, cold....it won't chill things that aren't cold. It works better with things that are cold already......
Post #309872 Mon Aug 15 2011 6:25am
firstinretail
So its a cooler ? my fridge at home makes stuff cold, maybe LR should call it a cool box Smile
Mine is used for spare change, there are enough shops about to buy cold stuff, and its usually cold here in the UK anyway.
I would suggest that if only your fridge is not working, praise the lord Bow down I have had mine (55 plate, well looked after by main stealers) 2 weeks and if anything else falls off or goes wrong, I think i will be left with a battery (probably flat) on the drive............... Big Cry
Post #309996 Tue Aug 16 2011 8:50am
LR do now call it a centre cooler box Thumbs Up
Post #310005 Tue Aug 16 2011 9:08am
Bobby
Even in 2005 it was called the "Cool Box" Thumbs Up Malaysia Boleh!
Post #310059 Tue Aug 16 2011 12:03pm
bagshawfred
There is nothing worse, especially on a hot day!!! Big Cry Instructions are just the manufacturers opinion
Post #310074 Tue Aug 16 2011 1:51pm
