![]() | Home > Technical > Fridge Not Working??? |
airwolf222helicopters Member Since: 25 Apr 2010 Location: kent Posts: 248 ![]() ![]() |
same on mine too light goes blue ,fan noise , same temp , glad im not just the only one
BIG DJ Member Since: 25 Oct 2009 Location: Heathrow Posts: 816 ![]() ![]() ![]() |
Couldnt believe it the other day when I got a hot drink out! |
firstinretail Member Since: 30 Jul 2011 Location: bolton Posts: 461 ![]() ![]() ![]() |
same here, very little tech advice about, me thinks most people just send them in to be fixed |
SOMEONE MUST KNOW ? |
We discussed this here..
chris mc Member Since: 03 Sep 2010 Location: Dundee Posts: 950 ![]() ![]() ![]() |
Having looked at a picture of one it appears to be a seperate unit from that of the AC system. Do you have the fridge out at the minute? |
Just read the link but unless I'm missing something I can't see what the problem is or a solution
oldcro Member Since: 25 Aug 2010 Location: Shetland Posts: 359 ![]() ![]() |
I've had my RRS now for 9 months and this thread has reminded me I have never tried the fridge. Must go fro a run tomorrow with a warm can of coke in the fridge and see what the result is. |
Right having read the link Bobby provided, i'm thinking the most likely problem is a break in the electrical connections of the elements (so to speak), this would explain why the fan would run but no cooling being produced.
NickM Member Since: 15 Feb 2008 Location: London Posts: 2995 ![]() ![]() |
Don't put a warm can in, put a cold one in. It keeps things that are cold, cold....it won't chill things that aren't cold. It works better with things that are cold already...... |
So its a cooler ? my fridge at home makes stuff cold, maybe LR should call it a cool box ![]() Mine is used for spare change, there are enough shops about to buy cold stuff, and its usually cold here in the UK anyway. I would suggest that if only your fridge is not working, praise the lord ![]() ![]() |
LR do now call it a centre cooler box |
Even in 2005 it was called the "Cool Box" |
bagshawfred Member Since: 10 Aug 2011 Location: Berlin, Germany Posts: 15 ![]() ![]() |
There is nothing worse, especially on a hot day!!! ![]() |
