| RRSPORT.CO.UK | ||
|  | Home > Maintenance & Modifications > Help Aircon |
| Siberianfox Member Since: 12 Mar 2011 Location: West Yorkshire Posts: 1495      | Easy... sell it ! I can believe you make your wife drive round in that !
|  Sun Jun 26 2011 3:57pm |
| chris mc Member Since: 03 Sep 2010 Location: Dundee Posts: 950      | Could be a number of issues but firtlsy I would check the Relays for the ac then move on to the heater valve but to be fair if the car is still under warrant get it booked in, that's what it's for lol | ||
|  Sun Jun 26 2011 4:12pm |
| leedsunited Member Since: 04 Aug 2008 Location: Selby Posts: 1368      |
 Her choice not mine   | ||
|  Sun Jun 26 2011 4:25pm |
| airwolf222helicopters Member Since: 25 Apr 2010 Location: kent Posts: 248    | check that you havent over filled with refridgerant , because if you overfill then it works in reverse
|  Sun Jun 26 2011 7:43pm |
| leedsunited Member Since: 04 Aug 2008 Location: Selby Posts: 1368      | Ok so booked it in for tommorow, when i spoke to the service lady first question she asked me was have you had the aircon serviced, no was my answer and it has always worked fine until the weekend and also the system is fully charged with refrigerant.
|  Wed Jun 29 2011 5:09pm |
 Air con is mostly excluded from warranty, best idea is to check your T&C's..... | ||
|  Wed Jun 29 2011 6:07pm |
 So you are saying that aircon is excluded from most manufacturers warranties  , now that i find very difficult to understand and would be very suprised as it is an itegral part and fixture of the car, do Land Rover exclude it from their warranties? Also noted that when sitting at idle there is no flutuation in RPM when the aircon is switched on and off so now thinking that it may be an issue other than refrigerant which is at the neccesary level. | ||
|  Wed Jun 29 2011 7:35pm |
| chris mc Member Since: 03 Sep 2010 Location: Dundee Posts: 950      | Right I think it best to start from scratch here.
|  Wed Jun 29 2011 8:42pm |
| Lookers Park Royal Member Since: 15 Nov 2007 Location: London Posts: 2303  | If climate control the likely to be the vent motor (diverting hot/cold). If AC then could also be the flap but also cable. If AC then see if temp dial feels like it has resistance?
|  Wed Jun 29 2011 8:44pm |
| leedsunited Member Since: 04 Aug 2008 Location: Selby Posts: 1368      | Chris Mc / James
|  Wed Jun 29 2011 8:55pm |
 Hope it's a simple fix for you and you get it on warranty. The amount of calls I have had about auto ac recently is unreal but it is simply something we do not do as a company | ||
|  Wed Jun 29 2011 9:03pm |
| leedsunited Member Since: 04 Aug 2008 Location: Selby Posts: 1368      | Update - What lovely those folks are at Toyota, think it may have been a loose connector but did a full service including de gas and re fill, also added some dye to see if there are any leaks and told me to run it constantly for 2 weeks and then take it back for them to check for leaks again.
|  Thu Jun 30 2011 7:54pm |
| chris mc Member Since: 03 Sep 2010 Location: Dundee Posts: 950      | Great stuff  | ||
|  Thu Jun 30 2011 8:09pm |
| Posting Rules
