![]() | Home > Maintenance & Modifications > Help Aircon |
| Siberianfox Member Since: 12 Mar 2011 Location: West Yorkshire Posts: 1495
Easy... sell it ! I can believe you make your wife drive round in that !
| chris mc Member Since: 03 Sep 2010 Location: Dundee Posts: 950
Could be a number of issues but firtlsy I would check the Relays for the ac then move on to the heater valve but to be fair if the car is still under warrant get it booked in, that's what it's for lol |
| leedsunited Member Since: 04 Aug 2008 Location: Selby Posts: 1368
Her choice not mine |
| airwolf222helicopters Member Since: 25 Apr 2010 Location: kent Posts: 248
check that you havent over filled with refridgerant , because if you overfill then it works in reverse
Ok so booked it in for tommorow, when i spoke to the service lady first question she asked me was have you had the aircon serviced, no was my answer and it has always worked fine until the weekend and also the system is fully charged with refrigerant.
Air con is mostly excluded from warranty, best idea is to check your T&C's..... |
So you are saying that aircon is excluded from most manufacturers warranties Also noted that when sitting at idle there is no flutuation in RPM when the aircon is switched on and off so now thinking that it may be an issue other than refrigerant which is at the neccesary level. |
Right I think it best to start from scratch here.
| Lookers Park Royal Member Since: 15 Nov 2007 Location: London Posts: 2303 |
If climate control the likely to be the vent motor (diverting hot/cold). If AC then could also be the flap but also cable. If AC then see if temp dial feels like it has resistance?
Chris Mc / James
Hope it's a simple fix for you and you get it on warranty. The amount of calls I have had about auto ac recently is unreal but it is simply something we do not do as a company |
Update - What lovely those folks are at Toyota, think it may have been a loose connector but did a full service including de gas and re fill, also added some dye to see if there are any leaks and told me to run it constantly for 2 weeks and then take it back for them to check for leaks again.
Great stuff |
