Home > Technical > Does the auto box learn driving style
The Kergan
United Kingdom 2013 Range Rover Sport 3.0 TDV6 Autobiography Nara Bronze
Hi everyone, it's me again Laughing
So another searching question, does the autobox get used to your driving style? This is my first auto, the D3 was manual.
I just seem to find that the car revs higher before changing up, or revs more than I would have allowed the manual D3 to have done, I would have changed gear sooner.
I am also finding that despite the D3 and the sport having the same size engine 2.7 I am not getting the same sort of mileage per gallon from it. I am getting About 20-22 around town and about 24-25 on the motorway doing about 70mph
Is this normal sort of mileage? What do you fine fellows get?
Post #300513 Mon May 23 2011 11:04pm
JC1
The auto box does learn your driving style, so drive like an old granny for a while and the box will be less aggressive. Although there will be times when you may be swearing at it to go at a roundabout or junction Thumbs Up MY10 3.0 HSE Santorini Black, Ivory Premium & extended leather, privacy, paddles, diamond turned alloys, Ipod lead that charges, tasmods, rrsport.co.uk stickers
Jeep 4.0 High Output XJ 94 6" teraflex lift, c/w rear coils, 9500lb winch, 35" TSL super swamper boggers, safari snorkel, custom made bumpers, tom woods custom double cardon driveshaft, twin electric fans. Don't follow it..............you wont make it. The first 4 x 4 by far.
Post #300516 Mon May 23 2011 11:36pm
mse
I was getting really stressed when i got mine that it would go to above 3k to change and i wasnt in a rush and didnt want it to.
Call it my driving style or it learning it doesnt that often at all...if i want it to go sport or paddles give me the control! Mike
2014 Facelift Discovery
Post #300613 Tue May 24 2011 5:23pm
I've found that if it's holding too low a gear, adding a bit more throttle for a second then backing off again will trigger the change up. Thumbs Up RRS gone
Post #301052 Sat May 28 2011 7:06am
Sabre1966
United Kingdom 2008 Range Rover Sport TDV6 HSE Santorini Black
i have noticed since i got mine that it has started to perk up with the gear changes, a dealer who serviced told me that the gear box would adapt to my style. He also told me to use the command shift as this would help it learn???
As i said it does seem to have perked up!
Post #301055 Sat May 28 2011 8:07am
CUCO
Spain
this is true,the gearbox learns, at least for me, a D4 owner 2010 MY TDV6 245, the gearbox give me a clunk! in the past when i did downshifts, and this was anoying me!!! and after some time (two or three times i drove the car, in the same day, more or less 50 km) using command shift and forcing it up and down shifts it goes perfect!! no clunks!!
try it!! you dont loose anything!!
Post #301705 Fri Jun 03 2011 1:03am
Bobby
Gentlemen, this is called the Adaptive Shift Strategy (ASIS)
The ASIS system is a new feature on automatic transmissions. With the TCM linked via the CAN bus to other vehicle systems, signals are received which can allow the TCM to calculate the way in which the vehicle is being driven. The type of signals include the following:
Longitudinal and lateral acceleration
Engine speed
Engine torque
Oil temperature
Accelerator pedal position
Wheel speed.
Using these signals, additional transmission control can be obtained. The TCM can calculate when the vehicle is cornering, all wheels are gripping, the driver is braking or if the driver is accelerating. This is the conventional 'Adaptive' transmission control. ASIS uses this system but adds the continuous adaptation of the gear changes to the individual driving style of the driver.
Smile Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #301707 Fri Jun 03 2011 1:26am
garrycol
Australia
Another example of Landrover outsmarting itself to our detriment. I normally have a relaxed driving style and because the gearbox has learnt this I have been caught out in some urgency situations where the gearbox would not change down when I require it - like overtaking etc. This is a dangerous setup and has no doubt caused accidents when the car would not provide the performance required of it.
Why do makers think their cars know better than the drivers.
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #301709 Fri Jun 03 2011 2:34am
KR1005
Hong Kong 2006 Range Rover Sport 4.4 V8 HSE Zermatt Silver
Does pre-2010 auto box learn driving style too?
Post #301805 Sat Jun 04 2011 3:02pm
Bobby
Yes! Malaysia Boleh!
Post #301811 Sat Jun 04 2011 4:34pm
Jmac
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
Garry
I hardly think it's dangerous.. If you know you're going to overtake, get the car ready by using command-shift.. Do you think people in manual cars think they're dangerous when they are in a hi gear??? Rolling Eyes
Post #301813 Sat Jun 04 2011 5:05pm
alanad
Scotland 2013 Range Rover Sport SDV6 HSE Bonatti Grey
Does the car not have a kick down - must admit never had to use it in the range rover, but in the Jag XF which had a similar transmission if you depress the accelerator fully then press down harder it shifts down a gear. 3.0 SDV6 HSE Dynamic, Corris Grey with contrast Santorini Black Panoramic Roof, lunar interior, privacy glass, upgraded Meridian system, cooled 18 way front seats, heated steering wheel, adaptive xenons, large screen wash bottle.
Gone: 3.0 TDV6 HSE, Santorini Black, Ivory/Lunar interior, grand black lacquer finish, HK Logic 7.1 Surround, Privacy Glass, Adaptive Xenons, heated steering wheel.
Gone: Jaguar XF Luxury, Pearl Grey, Dove Interior
Post #301815 Sat Jun 04 2011 6:02pm
simon1233
Garry
Not a problem with Landrover, but with ZF who make the boxes for many manufacturers including BMW etc. Their software controls the box and this is integrated into the cars systems. In my experience it works well and using the kick down gets the box to drop a couple of cogs when you need to shift in a hurry
Post #301839 Sat Jun 04 2011 11:03pm
garrycol
Australia
I agree that kickdown does occur - but when the car decides it is time to change down not when the driver wants it - usually there is, to quote an old military term, a 'pause of two marching paces" before anything happens. 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #301844 Sun Jun 05 2011 3:48am
Bobby
We have auto lights, auto wipers etc. There's no escaping these things. You'd be surprised how many decisions your car does for you while you're driving it. Smile
By the way Garry, even without the Adaptive Shift Strategy, your gearbox is already an auto and it is changing gears in a predetermined way. Wink Malaysia Boleh!
Post #301850 Sun Jun 05 2011 8:33am
