![]() | Home > Technical > Does the auto box learn driving style |
JC1 Member Since: 24 Oct 2009 Location: Berkshire Posts: 939 ![]() ![]() ![]() |
The auto box does learn your driving style, so drive like an old granny for a while and the box will be less aggressive. Although there will be times when you may be swearing at it to go at a roundabout or junction |
I was getting really stressed when i got mine that it would go to above 3k to change and i wasnt in a rush and didnt want it to.
I've found that if it's holding too low a gear, adding a bit more throttle for a second then backing off again will trigger the change up. |
Sabre1966 Member Since: 31 Mar 2011 Location: Essex Posts: 94 ![]() ![]() ![]() |
i have noticed since i got mine that it has started to perk up with the gear changes, a dealer who serviced told me that the gear box would adapt to my style. He also told me to use the command shift as this would help it learn???
CUCO Member Since: 02 Jun 2011 Location: Spain & Oleee!!! Posts: 59 ![]() ![]() |
this is true,the gearbox learns, at least for me, a D4 owner 2010 MY TDV6 245, the gearbox give me a clunk! in the past when i did downshifts, and this was anoying me!!! and after some time (two or three times i drove the car, in the same day, more or less 50 km) using command shift and forcing it up and down shifts it goes perfect!! no clunks!!
Gentlemen, this is called the Adaptive Shift Strategy (ASIS)
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1069 ![]() ![]() |
Another example of Landrover outsmarting itself to our detriment. I normally have a relaxed driving style and because the gearbox has learnt this I have been caught out in some urgency situations where the gearbox would not change down when I require it - like overtaking etc. This is a dangerous setup and has no doubt caused accidents when the car would not provide the performance required of it.
KR1005 Member Since: 03 May 2010 Location: Hong Kong Posts: 61 ![]() ![]() ![]() |
Does pre-2010 auto box learn driving style too? |
Yes! Malaysia Boleh!
Jmac Member Since: 17 Feb 2011 Location: South Posts: 125 ![]() ![]() ![]() |
I hardly think it's dangerous.. If you know you're going to overtake, get the car ready by using command-shift.. Do you think people in manual cars think they're dangerous when they are in a hi gear??? ![]() |
alanad Member Since: 01 Dec 2010 Location: Livingston Posts: 133 ![]() ![]() ![]() |
Does the car not have a kick down - must admit never had to use it in the range rover, but in the Jag XF which had a similar transmission if you depress the accelerator fully then press down harder it shifts down a gear. 3.0 SDV6 HSE Dynamic, Corris Grey with contrast Santorini Black Panoramic Roof, lunar interior, privacy glass, upgraded Meridian system, cooled 18 way front seats, heated steering wheel, adaptive xenons, large screen wash bottle.
simon1233 Member Since: 06 Jan 2011 Location: Leyland mostly, sometimes Darmstadt Posts: 421 ![]() ![]() |
Not a problem with Landrover, but with ZF who make the boxes for many manufacturers including BMW etc. Their software controls the box and this is integrated into the cars systems. In my experience it works well and using the kick down gets the box to drop a couple of cogs when you need to shift in a hurry |
I agree that kickdown does occur - but when the car decides it is time to change down not when the driver wants it - usually there is, to quote an old military term, a 'pause of two marching paces" before anything happens. 07MY RRS TDV6
We have auto lights, auto wipers etc. There's no escaping these things. You'd be surprised how many decisions your car does for you while you're driving it. |
