Home > Maintenance & Modifications > Help No Dipstick.......
Siberianfox
England 2011 Range Rover Sport 3.0 TDV6 HSE Siberian Silver
Im about to check the oil in my car ( my dad told me to), however in the MY11 there is no dipstick. Is nothing ever easy...
On finding out their is a service menu i try to run through the correct steps of checking my oil electronically.
It however is not working. I have tried to do this when the car is stationary and has not been run. Ive followed the instructions in the manual and still cant get a reading.
Can any one help? or offer suggestions?
Thanks Foxy ! Smile
Post #297167 Sun Apr 24 2011 9:42am
shepp
hello foxy
Hope this helps
http://www.rrsport.co.uk/forum/topic20417.html
Post #297170 Sun Apr 24 2011 10:07am
Siberianfox
thanks for that shepp however, no mention how to actually get the reading.
Thanks for trying to help ! Smile
Post #297171 Sun Apr 24 2011 10:32am
ChrisP
Foxy
I did this a couple of days ago,firstly your oil needs to be warm at operating temperature then switch your engine off for 10 minutes for all oil to settle then go though procedure detailed,if it is OK you just get "OK" come up,if not it tells you exactly how much oil to add. MY2011 HSE Santorini/Ivory/Piano Black/Privacy Glass/TV .Sadly gone.
Audi A5 Sportback Black Edition 3.0 tdi quattro S Line
Post #297177 Sun Apr 24 2011 11:01am
Siberianfox
Thanks chris I will try do this later as I'm now about to tuck into an easter egg ! Smile
Post #297179 Sun Apr 24 2011 11:10am
chris mc
Scotland 2011 Range Rover Sport TDV8 Autobiography Stornoway Grey
Do you not cycle through the menu with the car switched to point one to access a further part of the OBD. It tells you in the manual how to do it though.
Post #297180 Sun Apr 24 2011 11:12am
Siberianfox
Chris what do you mean switched to point one? Smile
Post #297181 Sun Apr 24 2011 11:13am
MAW
Possibly key in and to first position?
Post #297182 Sun Apr 24 2011 11:22am
Siberianfox
Oh its a keyless car .... God damn this im confused.com ! Smile
Post #297183 Sun Apr 24 2011 11:22am
MAW
Rolling with laughter Sorry Rolling Eyes Whistle
Laughing
Post #297184 Sun Apr 24 2011 11:24am
oldcro
Scotland
Make sure engine is hot then park on level ground, stop engine and wait 15 minutes. Then press start/stop button without pressing the brake pedal, this turns the ignition on without trying to start the car. Then check the level indication.
Post #297189 Sun Apr 24 2011 12:11pm
Siberianfox
Thanks oldcro ill try that ! Smile
Post #297190 Sun Apr 24 2011 12:13pm
DSL
What was wrong with the good old dipstick?? Rolling Eyes
Post #297194 Sun Apr 24 2011 4:10pm
oldcro
Scotland
Did you manage to check your oil level Siberianfox?
Post #297296 Tue Apr 26 2011 12:29am
Bobby
I believe from MY2010 onwards, there are no dipsticks in the engines! Wink
An ultrasonic sensor provides an electronic indication when the oil in the oil pan is low or high. This removes the requirement for the mechanical dipstick. An advantage in comparison with the static 'dipstick' method is that all marginal influences, for example vehicle being on a slope, lateral and longitudinal acceleration, are compensated for by averaging.
The values determined can be used to signal that the minimum oil level has been reached or to display the current oil level if required.
The sensor is mounted inside the oil pan where it sends an ultrasonic pulse vertically upward, it then measures the time for the pulse to be reflected back from the top surface of the oil.
Warnings will be displayed in the message center if the oil level is not maintained within the safe operating levels (minimum and maximum). A warning will also be displayed if there is a fault with the oil level monitoring system.
Hope this helps. Smile Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #297297 Tue Apr 26 2011 4:43am
