![]() | Home > Maintenance & Modifications > Help No Dipstick....... |
shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 440 ![]() ![]() ![]() |
hello foxy
Siberianfox Member Since: 12 Mar 2011 Location: West Yorkshire Posts: 1495 ![]() ![]() ![]() |
thanks for that shepp however, no mention how to actually get the reading.
ChrisP Member Since: 26 Jan 2008 Location: Derbyshire Dales Posts: 1392 ![]() ![]() ![]() |
Foxy
Thanks chris I will try do this later as I'm now about to tuck into an easter egg ! |
chris mc Member Since: 03 Sep 2010 Location: Dundee Posts: 950 ![]() ![]() ![]() |
Do you not cycle through the menu with the car switched to point one to access a further part of the OBD. It tells you in the manual how to do it though. |
Chris what do you mean switched to point one? |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 ![]() ![]() ![]() |
Possibly key in and to first position? |
Oh its a keyless car .... God damn this im confused.com ! |
oldcro Member Since: 25 Aug 2010 Location: Shetland Posts: 359 ![]() ![]() |
Make sure engine is hot then park on level ground, stop engine and wait 15 minutes. Then press start/stop button without pressing the brake pedal, this turns the ignition on without trying to start the car. Then check the level indication. |
Thanks oldcro ill try that ! |
DSL Member Since: 17 May 2006 Location: Heelands/Cobham (delete as appropriate) Posts: 1045 ![]() ![]() |
What was wrong with the good old dipstick?? |
Did you manage to check your oil level Siberianfox? |
I believe from MY2010 onwards, there are no dipsticks in the engines! ![]() An ultrasonic sensor provides an electronic indication when the oil in the oil pan is low or high. This removes the requirement for the mechanical dipstick. An advantage in comparison with the static 'dipstick' method is that all marginal influences, for example vehicle being on a slope, lateral and longitudinal acceleration, are compensated for by averaging. The values determined can be used to signal that the minimum oil level has been reached or to display the current oil level if required. The sensor is mounted inside the oil pan where it sends an ultrasonic pulse vertically upward, it then measures the time for the pulse to be reflected back from the top surface of the oil. Warnings will be displayed in the message center if the oil level is not maintained within the safe operating levels (minimum and maximum). A warning will also be displayed if there is a fault with the oil level monitoring system. Hope this helps. ![]() 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
