![]() | Home > Technical > range rover sport battery |
tornado34 Member Since: 06 Dec 2009 Location: London Posts: 242 ![]() ![]() |
I fitted a Varta SILVER dynamic (610 402 092 3162) to my TDV6. Direct fit, no messing. Not cheap, but huge crank power and cold start performance 110Ah!! Worth every penny. Left at the airport for three months and it fired up first time when I returned and turned the key. Check out their www, you can search by car model.
carlos50 Member Since: 04 Oct 2010 Location: North East Posts: 402 ![]() ![]() ![]() |
Ive noticed today that the connections on my genuine LR battery seem very specific, theres a steel connection plate type thing for the + terminal for example whereas normal battery terminals are just 2 connection stubs, does this matter when replacing the battery?.
Alicatt Member Since: 11 Jun 2007 Location: Eating in Eksel or Ice cold in Alex Posts: 1435 ![]() ![]() ![]() |
You lose some settings eg. clock, seats, mirrors but at least the memory points on the sat nav are retained ![]() Clan Cameron |
What about the different appearance of the connections, does that matter? |
Anyone ? |
simonw007 Member Since: 01 Dec 2010 Location: London Posts: 19 ![]() ![]() ![]() |
Carl, take another look at your battery. You should find the battery has two standard posts, one for +ve, the other for -ve (or ground). The +ve post is at the front of the car and has a metal multi-way connector head. This is part of the battery power distribution cable and should not need replacing with the battery.
Hi Simon
Xstyle Member Since: 14 Jul 2014 Location: Berkshire Posts: 46 ![]() ![]() ![]() |
RRS 2010 facelift 3L Diesel
harrygh60 Member Since: 16 Nov 2011 Location: London Posts: 395 ![]() ![]() ![]() |
The 150 amp less than the 950amp on original battery is the cold cranking power. It gives more of a kick when starting,without knocking out the battery. I put a Varta Silver H3 Battery on mine 100 amp 830amp Cold Cranking.5 Year Warranty .Have not had any problems itisme |
I'm going to return my Varta Blue and just get the standard 950a 90ah Range Rover battery Double the price though |
Why not get the Varta Silver H3 From EUROBATT Plymouth £82.44 Free Next Day Delivery 5 Year Warranty. I bought one in June its a 100amp No problems , and i have all the electric goodies Heated Steering Wheel, DRL,TV,Dvd player,Heated Seats, Etc. The Landrover One is a Varta Black 90 amp with a 3 Year Warranty Varta's Cheapest Battery and nearly twice the price of indie supplier itisme |
nigel52 Member Since: 20 Nov 2013 Location: Farnham Posts: 274 ![]() ![]() ![]() |
Just replaced my MY11 LR badged (actually VARTA) 90 A 950 cranking with Enduroline 100A 950 cranking at £89.77 next day delivery form Tayna Batteries who I used for years. They also offered the VARTA Silver with 100A 830 cranking for £94.99 delivered. The VARTA had a 5yr guarantee and the Enduroline had a 4yr guarantee. Decided on the Enduroline over Varta simply because so many Disco guys had recommended it.
Rosco1672 Member Since: 16 Aug 2014 Location: Scottish Borders Posts: 29 ![]() ![]() |
just check the voltage before you fit it,i had one delivered from tayna after getting the old one out and fitting the new on turned out it had a duff cell ended sending it back and getting one local.
