![]() | Home > General > Engine bay clean up? |
SkyWalker Member Since: 04 Sep 2009 Location: Marbella Posts: 540 ![]() ![]() ![]() |
The search option would have offered you this:
tommy-boy Member Since: 09 Jan 2011 Location: North East Posts: 96 ![]() ![]() ![]() |
How superbly observant of you "Skywalker" you are correct the search facility does bring up that thread. However the more educated of us are concerned about areas to avoid subjecting to water under pressure, along with personal opinions of people who have actualy done the task in hand, not just "use 303 it's rearly good"
"the more educated of us" |
The point I was trying to elaborate with previous post was that the search function is basicly crap. Its "searching" capabilities searched for a exit and once it found one it used it.
npinks Site Moderator Member Since: 27 Nov 2007 Location: Watching Posts: 6716 ![]() ![]() |
I use a brush with Megs APC or super degreaser, rinsed off low pressure
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1070 ![]() ![]() |
I would be very wary of spraying water in the engine bay area as there are modules that are not waterproof and rely on splash guards and things in the way to protect them from water splashed up from below but not from above.
BIG DJ Member Since: 25 Oct 2009 Location: Heathrow Posts: 816 ![]() ![]() ![]() |
Had problems with mine after pressure washing. Used the pressure washer from a distance aswell. All was fine until a couple of hours later when the alarm was going off and the car kept locking and unlocking it's self. Dash board, radio & satnav were also going on and off. Only way to stop it was to start the car. Took it for a drive to dry it and all was fine till 4 in the morning when it started again. |
