![]() | Home > General > Extended Warranty |
| Jimmy_75000 Member Since: 06 Oct 2006 Location: London, UK Posts: 1146
This as been discuss a lot of time... try to search... Range Rover Vogue ‘17 TDV6
| jamiequ1 Member Since: 23 Jan 2011 Location: london Posts: 58 |
Yes I have searched but can't get answers , what's the difference between extended and select , after your car has reached 75k does it change to select , |
| gilford Member Since: 07 Jan 2010 Location: Anglesey Posts: 542
To be fair the search function is pretty poor |
Nice one Gilford, that's what I was looking for |
No prob's The cost of the LR warranty depends on the mileage, but if oyu are under 75k and you take it without roadside assist its just over £600 IIRC I used to pay extra for roadside assist when I had the M3 but have only just realised I get full RAC cover with my bank account Always worth checking that out as I have probably wasted hundreds over the years |
| hogberto Member Since: 08 Jan 2011 Location: Edinburgh Posts: 67
http://www.usedvehicles.landrover.co.uk/fe...hicPromo_3 |
I was referring to the search function of the forum and not Google |
| chris mc Member Since: 03 Sep 2010 Location: Dundee Posts: 950
I did the same gilford, but to be honest i have LR Assist and will be keeping it after seeing a few RR's being towed by the rear wheels etc, this is NOT good for the car. You will also find that the free with your bank providers usually try to worm out of certain things, even with the comprehensive cover that they CLAIM to provide. I actually used LR Assist and they sent a technician to me from the other side of edinburgh quicker than my Green Flag cover could send a local contractor too!! |
Thanks for the info Chris, when my renewal is due mid summer I will take that into account |
The car is under 60 k miles,, Stratstones is offering ex warranty for £780 , is that about right? Also if I continue to buy warranty from them , even when you go past 75k is it the same warranty or does it change to select? Thanks guys |
| highfellzippy Member Since: 06 Dec 2009 Location: yorkshire Posts: 256
it changes to select after 5 years old |
| rrsjo Member Since: 28 Nov 2006 Location: North Cambs Posts: 551
From personal experience LR extended warranty is not worth the paper it is printed on. For instance two weeks after the 3yr factory warranty ran out it didn't cover the suspension knocking that keeps returning every few thousand miles. At the same time it didn't cover a defective battery. Put the money on one side for any repairs instead. Of course if the engine or gearbox blow up big time it might be worth having, but what are the chances of that happening? Slim I would have thought - unless you have a 911. |
| DSL Member Since: 17 May 2006 Location: Heelands/Cobham (delete as appropriate) Posts: 1045
Fair few blown engines on here!! |
I would not expect it to cover the battery , but would have thought the suspension was covered ? I no what you mean about 911 mine blew twice |
| All times are GMT |
