Home > General > Help - spare key dropped below rear seat!
kismet110
Hi all
This morning I accidentally dropped the spare key through the gap where the seat belt clips in on the rear seat. Tried pulling the seatback forward to get my hand in behind it but no luck Sad
Is there any way of getting the plastic cover at the front of the seat off? Failing that, how easy is it to remove the seat completely?
Really annoyed with myself but at least it was the spare key and, failing all else, I can mention it at service time next week so hopefully they will retrieve it for me...
Post #288379 Tue Feb 08 2011 10:21am
The whole rear seat comes up and forwards (for loading the boot up)
Can you not get access doing that? RRS gone
Post #288380 Tue Feb 08 2011 10:39am
dazsear
Slide your hand down the back of the seat and rub left/right.....you will feel a little loop of leather and tug it to lift the seat base forwards.
There is masses of room under the seat....hey look in my gallery you can see I even had a PS3 under my seat!
Daz 2017 4.4 Autobiography FFRR - love this car
Gone - VW T5 Transporter
Long gone - 2009 Disco
Long gone but never out of my thoughts - 2008 TDV8 HST
Post #288381 Tue Feb 08 2011 10:42am
kismet110
Thanks guys, I will try that tonight. When I was moving my hand in vain back and forth earlier on I couldn't feel any leather loop or similar but admittedly wasn't actually looking for it - no doubt the handbook may come in useful on this one Embarassed
Post #288382 Tue Feb 08 2011 11:06am
carlos50
Its in the back corner, you should see it when you open the doors. Don't look towards the centre, its at the very outer edge.
Post #288398 Tue Feb 08 2011 12:58pm
My tabs are located centrally to each outer seat (one on each side). They've probably just been pushed down between the leather iso-fix cover and the seat base. RRS gone
Post #288402 Tue Feb 08 2011 1:16pm
carlos50
Must have changed then, mine are outer edge of each seat. 2005 RRS S/C
Post #288404 Tue Feb 08 2011 1:19pm
Must have Thumbs Up
Best look where Carlos's are then Mr. Green RRS gone
Post #288405 Tue Feb 08 2011 1:22pm
kismet110
Thanks people, tried this last night but no luck Embarassed I'd already located the 'catch' at the top corner of the seat no problem. After reading on here about the loop of leather underneath the seat I released the catch, found the loop but no amount of tugging would move the seat fully forwards/collapsed so I can fully see underneath it?
Am I supposed to pull this loop upwards or forwards? At one stage I was balanced on the sidesteps and had both hands on the loop pulling at it (not easy anyway due to location) but it didn't budge at all; best I get is back of the seat forward so can get my hand underneath the seat but not reach too far or see a thing.
Probably me being dense (handbook description is awful too) but any tips would be appreciated....
Post #288512 Wed Feb 09 2011 9:45am
hmmmm sounds like something's jammed.
It's a one finger pull release on the 2007 car, literally zero effort and the whole seat base hinges forwards after a click. RRS gone
Post #288513 Wed Feb 09 2011 9:52am
Have you tried the other side?
I take it you're trying to hinge the seat base forward before releasing the seat back Whistle
I'll take some pics of mine to show how it all works if you want... RRS gone
Post #288516 Wed Feb 09 2011 9:59am
dazsear
You have to pull upward, the seat pads are hinged at the front so the rear has to come up and arcs toward the front seat.
The end position is the seat base in the vertical position which allows the rear seat back to fold flat into the space once occupied by the seat pad.
I have to say that I used to push the leather loops under the seat if I ever parked the car up at night with the PS3 installed, that way scallies would not be able to lift the seats unless they knew what they were doing.
Hope thi shelps
Post #288517 Wed Feb 09 2011 10:18am
kismet110
Thanks again all. Not tried the other side, did try pulling upwards but no movement at all.
Pictures would be very much appreciated, really don't want to lose the main key and be left cursing the fact the spare key is INSIDE the locked car Embarassed
Post #288519 Wed Feb 09 2011 11:25am
A12DY B
there is a release mechanism,
you have to feel for the black straps, once you have found them its easy
Post #288522 Wed Feb 09 2011 11:35am
2007 RRS so tab may be to side of seat as per Carlos's post
The tab pulls a release catch inside this square recess (sorry dark pic but recess is central to the seat base)
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  RRS gone
Post #288527 Wed Feb 09 2011 11:51am
