![]() | Home > General > Help - spare key dropped below rear seat! |
| awd man Member Since: 30 Nov 2010 Location: Malmesbury Posts: 3355
The whole rear seat comes up and forwards (for loading the boot up)
| dazsear Member Since: 23 Nov 2008 Location: Lincolnshire Posts: 851
Slide your hand down the back of the seat and rub left/right.....you will feel a little loop of leather and tug it to lift the seat base forwards.
| kismet110 Member Since: 09 Oct 2010 Location: London Posts: 382
| carlos50 Member Since: 04 Oct 2010 Location: North East Posts: 402
Its in the back corner, you should see it when you open the doors. Don't look towards the centre, its at the very outer edge. |
My tabs are located centrally to each outer seat (one on each side). They've probably just been pushed down between the leather iso-fix cover and the seat base. RRS gone
Must have changed then, mine are outer edge of each seat. 2005 RRS S/C |
Must have |
hmmmm sounds like something's jammed.
Have you tried the other side?
You have to pull upward, the seat pads are hinged at the front so the rear has to come up and arcs toward the front seat.
| A12DY B Member Since: 21 May 2008 Location: WEST MIDS Posts: 335
there is a release mechanism,
2007 RRS so tab may be to side of seat as per Carlos's post
| All times are GMT |
