![]() | Home > General > parking sensors front/rear replace help please |
These issues have been discussed umpteen times - do a search please! |
simonw007 Member Since: 01 Dec 2010 Location: London Posts: 19 ![]() ![]() ![]() |
Luckily Bobby has posted the front and rear bumper cover removal procedures in his gallery:
ptwroofing Member Since: 30 Dec 2010 Location: hertfordshire Posts: 38 ![]() ![]() ![]() |
many thanks did you have to have the clock reset or does the replacement of the faulty sensors correct the message on the dash cheers paul paul |
From reading through other posts I believe the replacement of the faulty sensor is enough and then the control unit reverts to normal operation. I wont be able to test this for sure until my replacement sensors arrive and I change it over.
got the exact same problem front parking ade inactive flashing light with long tone this has stopped front and rear sensors so not sure which ones to check front or rear or just replace all as 4 new sensors on e bay only £60 paul |
merwiz Member Since: 26 May 2009 Location: Wirral Posts: 143 ![]() ![]() ![]() |
I had the same fault, but traced it to the offside front sensor.
I put the car in reverse like someone else said on this site and listen for the clicking on each sensor and they said the 1 that's not clicking is the faulty 1 but all mine are clicking front and rear so do you think it could be a fault on the wires somewhere |
Sorry, I don't know the answer to the sensor clicking question. However, I have ordered the 4 oem sensor set from ebay for £60 and plan to change all four fronts.
