| RRSPORT.CO.UK | ||
|  | Home > Maintenance & Modifications > frozen bits |
| carbostar Member Since: 13 Jun 2010 Location: the north Posts: 27      |
 Duno someone might know, bit disappointed that the washer system freezes up at the hint of frost;
|  Thu Dec 23 2010 9:30am |
| Very Annoyed Site Moderator Member Since: 23 Aug 2005 Location: bat-wielding monkey-spanking tough-love zero-tolerance Euro-sceptic moderator - So just watch it! Posts: 19459    | You need to use virtually neat washer liquid then it doesn't freeze! 2005 Zambezi TDV6 - Gone but not forgotten
|  Thu Dec 23 2010 9:37am |
| carlos50 Member Since: 04 Oct 2010 Location: North East Posts: 402      | James
|  Thu Dec 23 2010 12:10pm |
| Lookers Park Royal Member Since: 15 Nov 2007 Location: London Posts: 2303  | Sorry, by NW I mean Not Working.
|  Thu Dec 23 2010 12:16pm |
| DSL Member Since: 17 May 2006 Location: Heelands/Cobham (delete as appropriate) Posts: 1045    | Try this stuff, should be good enough neat.
|  Thu Dec 23 2010 12:59pm |
| bradtarga34 Member Since: 19 Jan 2010 Location: Walton-on-Thames Posts: 147  | That's the stuff I use, very good. Otherwise I use the shell screenwash neat and have no problems freezing.
|  Thu Dec 23 2010 2:24pm |
| DSL Member Since: 17 May 2006 Location: Heelands/Cobham (delete as appropriate) Posts: 1045    | Presently using Halfrauds normal stuff neat in my D3 neat.  Says good down to -15c but in reality works down to -11c.  Once that stuff is used up will get some Comma stuff, couple of places listed in Leatherhead.  Mind you have "winter" mix level (1:4 conc ISTR) of Halfrauds stuff in SWMBO's D3, tends to be good enough for Surrey at around freezing.   Any colder and we use my car with its heated steering wheel!!  | ||
|  Thu Dec 23 2010 2:35pm |
| carbostar Member Since: 13 Jun 2010 Location: the north Posts: 27      | You see i knew there would be a simple 'solution'  | ||
|  Mon Dec 27 2010 7:46pm |
| Endjin Member Since: 22 Jun 2007 Location: Aberdeenshire Posts: 2087    | I use neat washer fluid from either Halfords or Costco. We have had -20 Degrees C several times this winter
|  Tue Dec 28 2010 1:53pm |
| chris mc Member Since: 03 Sep 2010 Location: Dundee Posts: 950      | I assume that the headlight washer jets are the same fuse as the windscreen washer jets (F11) can someone confirm this, there does not appear to be a seperate fuse for them in the manual. | ||
|  Tue Dec 28 2010 6:02pm |
| Posting Rules
