Home > Maintenance & Modifications > frozen bits
carbostar
United Kingdom 2012 Range Rover Sport 3.0 TDV6 Autobiography Orkney Grey
frozen bits
Duno someone might know, bit disappointed that the washer system freezes up at the hint of frost;
love the heated seats as im getting a bit soft in my advancing years, but the washer system freezing up is a bit 'Austin Allegro' after all how do you off road all terrain guys manage,
Anyone got any thoughts? I know you can get a ribbon system to wrap around domestic water pipes (240v), and I know I could make a version ( and have done for other situations), but the insurance co might not be happy; so is there a retro fit system out there?, before I run over a muddy cyclist as they can be the same color as the windscreen.
I will rant about heated stearing wheels next time. a womans rule of thumb:if it has tyres or testicles your going to have trouble with it
Post #283849 Thu Dec 23 2010 9:30am
You need to use virtually neat washer liquid then it doesn't freeze! 2005 Zambezi TDV6 - Gone but not forgotten
Post #283850 Thu Dec 23 2010 9:37am
Lookers Park Royal
Either your washer fluid is too weak or your washer jets are NW. Mine were working at -17 the other night!!
I'm currently using LR concentrate Screenwash at a ratio of 1:1.
James Thumbs Up
Post #283851 Thu Dec 23 2010 9:57am
carlos50
James
Mine freezes up very easily also, is the LR concentrate an anti freeze additive or screenwash in its own right such that it can be used all year round?
When you say washer jets ar NW, what do you mean please?
Post #283862 Thu Dec 23 2010 12:10pm
Lookers Park Royal
Sorry, by NW I mean Not Working.
Yes screenwash should have antifreeze in it (LR supplied antifreeze does), therefore you adjust the ratio of screenwash to water depending on what time of the year it is. In summer you would probably use 1:4 and in winter (upto -10) it is 1:1 from memory, however any colder than theat then you probably need a specialist antifreeze.
James Thumbs Up
Post #283863 Thu Dec 23 2010 12:16pm
DSL
Try this stuff, should be good enough neat.
http://www.commaoil.com/productsguide/view/6/305/XSW5L
Post #283869 Thu Dec 23 2010 12:59pm
bradtarga34
That's the stuff I use, very good. Otherwise I use the shell screenwash neat and have no problems freezing.
Post #283883 Thu Dec 23 2010 2:24pm
DSL
Presently using Halfrauds normal stuff neat in my D3 neat. Says good down to -15c but in reality works down to -11c. Once that stuff is used up will get some Comma stuff, couple of places listed in Leatherhead. Mind you have "winter" mix level (1:4 conc ISTR) of Halfrauds stuff in SWMBO's D3, tends to be good enough for Surrey at around freezing. Any colder and we use my car with its heated steering wheel!! Thumbs Up
Post #283886 Thu Dec 23 2010 2:35pm
carbostar
You see i knew there would be a simple 'solution' Very Happy a womans rule of thumb:if it has tyres or testicles your going to have trouble with it
Post #284154 Mon Dec 27 2010 7:46pm
Endjin
Scotland
I use neat washer fluid from either Halfords or Costco. We have had -20 Degrees C several times this winter
already and I have had no issues with freezing at all Thumbs Up 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black
2013 Evoque 5 Door Pure Tech SD4 - Orkney Grey with Panoramic Roof (Mrs E's new baby)
GONE - RRS - 3.0 TDV6 HSE - Santorini (2010)
GONE - RRS - 2.7 TDV6 HSE - Java Black (2007)
GONE - Porsche Boxster S - 3.2 - Black
Post #284210 Tue Dec 28 2010 1:53pm
chris mc
Scotland 2011 Range Rover Sport TDV8 Autobiography Stornoway Grey
I assume that the headlight washer jets are the same fuse as the windscreen washer jets (F11) can someone confirm this, there does not appear to be a seperate fuse for them in the manual.
Post #284221 Tue Dec 28 2010 6:02pm
