Home > Technical > No power and no acceleration (solved) |
Tboner Member Since: 03 Dec 2008 Location: Bucks - UK Posts: 447 |
Inter cooler pipe ? 2014 5.0SC AB
Sat Dec 18 2010 8:14pm |
PHYLRRS Member Since: 18 Sep 2009 Location: Brabant Posts: 18 |
Hi Tboner. Is the pipe leaking then or what? Or dirty inside? |
Sat Dec 18 2010 8:26pm |
leaking only an idea , 2014 5.0SC AB
Sat Dec 18 2010 8:58pm |
DSL Member Since: 17 May 2006 Location: Heelands/Cobham (delete as appropriate) Posts: 1045 |
Intercooler hose, probably split. Alternative is turbo failure so lot cheaper to check out hose first. |
Sat Dec 18 2010 9:18pm |
AdamRRS Member Since: 20 Dec 2010 Location: Doncaster Posts: 3 |
hi there PHYLRRS, have you found the cause yet? i have had the same problem, i think it might be temperature related as it was -10 outside |
Mon Dec 20 2010 11:53pm |
Not 100% sure but Probably a EGR valve issue.
Tue Dec 21 2010 1:17am |
yes its the tdv6 2.7 MY06 |
Tue Dec 21 2010 1:30am |
Fitted new EGR valves today and she`s sweet thanks guys |
Thu Dec 23 2010 8:46pm |
Went to dealer today.
Fri Dec 24 2010 7:05pm |
tonser Member Since: 17 Jan 2006 Location: Cobham, Surrey Posts: 244 |
Hi guys
Tue Jan 11 2011 12:38am |
Option a: egr blanking kit and a couple of hours of your time with a spanner (£12 off ebay for the kit)
Tue Jan 11 2011 5:46pm |
If you go for the blanking plates does that not screw up the computer ?
Tue Jan 11 2011 5:48pm |
I thought it was 2007 onwards that have the issue
Tue Jan 11 2011 5:50pm |
There is another option I forgot
Tue Jan 11 2011 5:58pm |
