![]() | Home > Technical > Major Airlock |
| carlos50 Member Since: 04 Oct 2010 Location: North East Posts: 402
I had this with a BMW some years back and was told to keep filling the system and it will force the air out as you pour more coolant in there. The system i had used a breather overflow which i could hear the air hissing out as i poured more coolant down the filler neck.
| Harry HST Member Since: 09 Feb 2010 Location: Birmingham Posts: 296
Hi Carlos
| AlexMckie Member Since: 26 Nov 2009 Location: Devon Posts: 174
All you can do is get the car inside some where and warm the whole car up for a day or so and try again....
| MikeS Member Since: 24 Dec 2009 Location: Parkdale, Melbourne Posts: 261
Harry, you do have the heater set to fully hot don't you ? In my (albeit limited) experience of bleeding the air from coolant systems the heater always had to be set to full hot, otherwise the systems not fully open.
| chris mc Member Since: 03 Sep 2010 Location: Dundee Posts: 950
Have you tried squeezing any coolant hoses you can access as this will help "pulse" the water through.
| Bobby Member Since: 07 Jun 2005 Location: Kuala Lumpur Posts: 3781
Maybe you need to do the LR method of "Cooling System Draining, Filling and Bleeding" |
I've kept the heaters on full whilst bleeding it whilst topping it up with water and bleeding the air.
| All times are GMT |
