![]() | Home > Off Topic > LinkedIn |
anthony-apl Member Since: 07 Oct 2007 Location: sunny stockport Posts: 259 ![]() ![]() ![]() |
A mate of mine mentioned it the other week actually will check it out
leedsunited Member Since: 04 Aug 2008 Location: Selby Posts: 1368 ![]() ![]() ![]() |
Very good networking medium and worth checking out |
Kaine Member Since: 27 May 2006 Location: Hills of Shropshire Posts: 8902 ![]() ![]() |
yep - use it |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1941 ![]() ![]() ![]() |
I won't set up my own account because I think that there is a lot of exaggeration in the profiles.
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 ![]() ![]() ![]() |
That is the same in most online environments - I am on there and it has uses.... |
chris mc Member Since: 03 Sep 2010 Location: Dundee Posts: 950 ![]() ![]() ![]() |
I am on it but never use it much.
I think he cant have many connections as they would know he is a Bull *******, you cant really lie in your profile on LinkedIn and get away with it. |
Chris you have an invitation. ![]() |
Cheers, It is a bit different to use, i am still very much getting used to finding my way around it. I joined to primarily get my business out there and recognised. |
Chris - Think the big benefit is to seek out all the forums that may be pertinet to your business and also local for networking. One that i am in is The Yorkshire Mafia, 4000 members and geared to social events, networking Yorkshire businesses to do business with Yorkshire based companies.
Jonny Fresh Member Since: 04 Feb 2008 Location: Manchester Posts: 3586 ![]() ![]() |
LinkedIn is a waste of time in my opinion...... |
That is what i thought two years ago but it helped me secure a position and in turn lead me to a £70K order, so not a bad return for a little bit of work. |
2nd Rower Member Since: 12 Nov 2007 Location: Upside Down Posts: 1382 ![]() ![]() ![]() |
There are two types in my view... Those that lie, and those that exaggerate.. I've easily uncovered exaggeration in traditional paper CV's when interviewing, so as long as you conduct the same due diligence you should be able to work out those to believe... and if you don't believe them don't link them and don't provide a recommendation! I know a guy who in 10 years in an org was acting CEO for the 9 months before he left.. His profile now shows just one role for his ten year stint "CEO".. go figure! |
flydive Member Since: 17 May 2007 Location: South Posts: 1213 ![]() ![]() ![]() |
Yes I'm on it too, got there after a couple of invitation from friends in the same line of work, but I do not use it much, should do more. '08 RRS TDV8
