Home > Tips & Tricks > Continental 275/40 R 20 Tyres
MJW267
Just a heads up to anyone fiting the Continental 275/40 R20 Tyre to make sure that they fit the right model as Continental make 2 versions of this tyre in this size.
The 275/40 R 20 is the one you want for your RRS NOT the 275/40 R 20 "NO" (as marked on the sidewall) which Continental designed specifically for Porsche. Continental told me that the NO version would last half as long as the regular version on an RRS which is backed up by a friend of mine who got through a new set of NOs in just under 9k miles!
More remarkable is that his first set of factory fitted Continentals lasted 25k miles and the NOs were fitted by a local reputable tyre fitter as part of a service by our local Land Rover dealer. Neither the Tyre fitter or the dealer were aware that 2 models existed.
Post #276603 Fri Sep 24 2010 2:14pm
Interesting - hadn't herd that one before. Thanks. 2005 Zambezi TDV6 - Gone but not forgotten
Post #276607 Fri Sep 24 2010 2:30pm
Endjin
Scotland
Shocked That's a great bit of info MJW267. Thumbs Up 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black
2013 Evoque 5 Door Pure Tech SD4 - Orkney Grey with Panoramic Roof (Mrs E's new baby)
GONE - RRS - 3.0 TDV6 HSE - Santorini (2010)
GONE - RRS - 2.7 TDV6 HSE - Java Black (2007)
GONE - Porsche Boxster S - 3.2 - Black
Post #276627 Fri Sep 24 2010 6:51pm
sworks
Scotland 2010 Range Rover Sport 3.0 TDV6 HSE Galway Green
Just got a full set replaced at 14500 miles, shoulder tread had started to wash out, have replaced these with Pirelli
Post #281335 Sun Nov 28 2010 8:18pm
Which Pirelli did you go for? I'm looking at what to put on next to replace the Goodyear Wrangler F1s that mine came with. They're ok in the dry but don't seem to like standing water very much. 2012 SDV6 - it's missing a couple of cylinders
Post #310512 Thu Aug 18 2011 6:09pm
V8 andy
England 2009 Range Rover Sport TDV8 HSE Arctic Frost
If your fitting conti's you need the 106Y XL,,,,,NOT the 106Y NO.
Andy. Gone,,TDV8 arctic frost,black leather,colour coded handles,rear entertainment,sunroof.
1980 Rolls Royce,shadow 2 in white.
Gone 07/57 TDV8 santorino,black leather.chrome handle's/mirror's.
Gone 02/52 FFRR vogue.
Post #310514 Thu Aug 18 2011 6:28pm
flydive
I'm carefully avoiding Continentals for the RRS, so not an issue Wink '08 RRS TDV8
Post #310636 Fri Aug 19 2011 8:16pm
SONYBOY
United Kingdom 2007 Range Rover Sport TDV6 HSE Zermatt Silver
need to look at this,just changed mne round Rolling Eyes 2007 COOLRRS
Post #326288 Tue Dec 27 2011 5:54pm
airwolf222helicopters
Got a new set sitting in garage must have a look before I put them on wheels Embarassed hope they ar not the No's
Post #326294 Tue Dec 27 2011 8:09pm
RRS-Spy
All Porsches have specific tyres made by the various tyre manufacturers. They are only for Porsche cars and are recongnised by the marking. N0, N1, N2, N3 etc
The higher the number, the later the incarnation of Porsche tyre. For example, on my 911 I have N1 tyres but they no longer make these so next time I have them changed, I will be looking at N3 tyres.
Similarly, on my wife's Audi, I look for tyres marked with AO which are specific tyres/rubber compound for Audi cars Proud owner of a 2008 TDV8 HSE.....and an Audi A3 2.0T DSG Cab and a Porsche 911 Turbo (Mercedes W208 320 CLK and Mercedes W124 E220 Estate now gone)
Post #326297 Tue Dec 27 2011 9:58pm
checked today on the new set in garage and they are xl Very Happy
Post #326459 Thu Dec 29 2011 9:45pm
Have to say that I'm surprised anyone with more than a passing interest in cars didn't know any of this...
Shocked 2012 SDV6 - it's missing a couple of cylinders
Post #326468 Fri Dec 30 2011 12:59am
Supacat
Are you aware of LR publication on this issue:
Issue.
A customer may report uneven tyre wear on
vehicles fitted with 20 inch wheels and
Continental 4x4 Sport Contact tyres.
Cause.
With reference to the photo attached, Due to
the tread pattern design of this tyre, there can
appear to be inner or outer shoulder wear. This
is in fact just the natural tread wear, but as the
design of the lateral grooves continues around
to the sidewall, the very ends of the grooves do
not wear giving rise to a "band" of wear at the
edge of the contact patch.
Action.
No action is required for this issue as it is
deemed a characteristic of the tyre and not a
fault.
Having said that there was an earlier TSB - No.LS204-009V2 A customer may report a concern of uneven tire wear.
Cause: Certain vehicles may experience a degree of 'bush settle' after the initial geometry setting following production (this has now been compensated for using calculated geometry settings introduced from the VIN above). This 'bush settle' may change the geometry settings to outside of normal tolerance and may increase tire wear. This issue is not experienced on all vehicles and the toe sensitivity may be attributed to other factors.
Action: Should it become necessary to adjust vehicle geometry due to specific complaints of tire wear, or where the components detailed below have been changed, the geometry should be set to the target values detailed in this bulletin. These target values are within the geometry specifications detailed in the workshop manual but are purposely detailed to address the above concern.
Target Values
Adjustment
Specification (degrees/minutes)
Front total toe
0° 02'
Left-hand rear toe
0° 11'
Right-hand rear toe
0° 11'
Rear total toe
0° 22'
NOTE: The air suspension tight tolerance mode should be activated when checking/setting geometry (refer to the procedure on GTR).
Post #326481 Fri Dec 30 2011 8:51am
Bobby
Had this in my Gallery sometime back...
http://www.rrsport.co.uk/gallery/albums/us...rn%7E0.pdf Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #326487 Fri Dec 30 2011 10:11am
Supacat
Bobby - my apologies - that's probably where I data mined it from some time ago Embarassed . It was just easier to find on my laptop Thumbs Up
Post #326494 Fri Dec 30 2011 11:24am
