Home > Technical > HELP! Exhaust Gasket leaking TDV8
rrstdv8luxembourg
Luxembourg 2007 Range Rover Sport TDV8 HSE Java Black
I have a problem on my TDV8. An exhaust gasket is leaking and it make a whistling noise. My dealer told me that maybe a screw was broken. But to fix it they have to pick up the whole body to access the gasket. He told me that it will be a very expensive repair (3000-4000€). Can anyone tell me if there is another possibility to repair it, or does anyone has an address where i can get it repaired for less? Thank you
Post #271532 Sat Jul 17 2010 2:52pm
Tim in Scotland
Do you have any warranty left? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #271537 Sat Jul 17 2010 3:51pm
rrstdv8luxembourg
No, that's the problem
Post #271542 Sat Jul 17 2010 4:39pm
leedsunited
United Kingdom 2008 Range Rover Sport TDV6 HSE Java Black
What kind of idiot designs a car that you have to lift the whole body off to gain access to the exhaust gaskets, are these guy's on drugs!!!
Post #271572 Sun Jul 18 2010 9:55am
Bobby
Which exhaust gasket? Can you be specific?
Is your exhaust system with or without DPF? Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #271577 Sun Jul 18 2010 10:44am
rrstdv8luxembourg
It is with DPF. The problem is where the exhaust is fixed on the engine. Due to high temperatures the material is deforming and so apparently a screw from the fixation is broken. Sorry for my english Wink
Post #271927 Thu Jul 22 2010 8:47pm
rrstdv8luxembourg
Post #271928 Thu Jul 22 2010 8:47pm
Bobby
Print THIS out and show it to your dealer.
Ask him if he can do it. Wink Malaysia Boleh!
Post #271937 Thu Jul 22 2010 10:07pm
rrstdv8luxembourg
Thank you Bobby,
So if i have right understood, it isn't necessary to lift off the body from the chassis to get to the exhaust gasket at the engine and to change the screws and the collector?
That would be great!
Post #271978 Fri Jul 23 2010 9:12am
rrstdv8luxembourg
Thank you Bobby,
Post #271979 Fri Jul 23 2010 9:12am
Bobby
rrstdv8luxembourg,
The TDV8 exhaust system is supplied as three separate assemblies; a LH (left-hand) front section incorporating a catalytic converter, a RH (right-hand) front section incorporating a catalytic converter and a rear section incorporating a centre silencer and two rear silencers.
The sections of the system can be replaced individually. Service joints are identified by indentations on the pipes which show where the exhaust pipes can be cut to accommodate replacement sections.
Your dealer should be able to identify which gasket is leaking in the front, left or right side. The part which you say is fixed to your engine is a welded flange with three holes and it is attached to the turbocharger using three bolts. In between will be a metal gasket. From your description it looks like this metal gasket is gone and probably one of the bolts is broken.
Anyway, your dealer should be able to locate the service joint for this section and cut the pipe. Alternatively, get them to take the whole exhaust out as per the earlier instructions, replace the relevant gasket and bolt and fix it back!
Laughing Malaysia Boleh!
Post #271994 Fri Jul 23 2010 10:45am
jason.abel1
Hello.
I am currently at the moment having mine repaired. For the V8 if it is the exhaust manifold gasket YES it is a body removal job. I recieved email yesterday from my dealer saying they had to also remove several broken studs and re thread the manifold. Should have it back tommorow, they have had it one week. Total cost £1187.
Post #355067 Thu Aug 30 2012 3:40am
DMike
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
I can confirm, body off to drill out a broken manifold stud and/or replace the manifold gaskets
Have done this myself a few times already, caused by warped manifolds :thumbsup:
Post #355279 Sat Sep 01 2012 2:09pm
bulletooth
United Kingdom 2006 Range Rover Sport TDV6 HSE Stornoway Grey
same thing happened to my friends TDV8 .. and he drilled of his studs out without removing the body .. cant remember how he did it , he had to modify some sort of drill bit to do it but he managed to get it done without removing the body anyhow Smile
Post #355287 Sat Sep 01 2012 3:16pm
