![]() | Home > Technical > HELP! Exhaust Gasket leaking TDV8 |
rrstdv8luxembourg Member Since: 15 Feb 2010 Location: Contern Posts: 30 ![]() ![]() ![]() |
No, that's the problem |
leedsunited Member Since: 04 Aug 2008 Location: Selby Posts: 1368 ![]() ![]() ![]() |
What kind of idiot designs a car that you have to lift the whole body off to gain access to the exhaust gaskets, are these guy's on drugs!!! |
Which exhaust gasket? Can you be specific?
It is with DPF. The problem is where the exhaust is fixed on the engine. Due to high temperatures the material is deforming and so apparently a screw from the fixation is broken. Sorry for my english |
Print THIS out and show it to your dealer.
Thank you Bobby,
Thank you Bobby,
rrstdv8luxembourg,
jason.abel1 Member Since: 02 Jun 2012 Location: Norfolk Posts: 3 ![]() ![]() ![]() |
Hello.
DMike Member Since: 09 Nov 2007 Location: Perthshire Posts: 79 ![]() ![]() ![]() |
I can confirm, body off to drill out a broken manifold stud and/or replace the manifold gaskets
bulletooth Member Since: 13 Aug 2012 Location: Berkshire Posts: 22 ![]() ![]() ![]() |
same thing happened to my friends TDV8 .. and he drilled of his studs out without removing the body .. cant remember how he did it , he had to modify some sort of drill bit to do it but he managed to get it done without removing the body anyhow |
