Home > Maintenance & Modifications > Purchasing an Extended Warranty?
kevinlagan
Northern Ireland 2005 Range Rover Sport TDV6 HSE Java Black
Was thinking about purchasing an extended warranty for my RRS. Has anybody any thoughts/advice/horror stories on this subject? Would appreciate the guidance. Saw this one....not sure...http://www.carprotect.co.uk
Post #260134 Fri Mar 19 2010 10:43am
quantz
2010 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Here you can buy one from dealers, serviced by a private company.
I don't know in the UK. 2010 TDV6 3.0 HSE Santorini Black Tan Full Leather
Post #260144 Fri Mar 19 2010 12:15pm
Cavham
2011 Range Rover Sport 3.0 TDV6 HSE Santorini Black
I also was thinking about this 6 mths ago and got the car checked over from a indi to see what they thought could be on its way out.
In short, the car was given the thumbs up and did not bother with the extended warranty and have not had anything going wrong with it.
Its really up to you if you need peace of mind
Post #260149 Fri Mar 19 2010 12:49pm
scott7
Scotland
My lr warranty expired recently and I was reluctant to fork out the ammount lr wanted to renew it, after a bit of research I decided to buy a non lr warranty which turned out to be a bit of a nightmare, I ended up getting most of my money back and buying the lr warranty.
If your buying a non lr warranty you have to make sure it will cover the full labour hourly rate of the garage you want to use, the one I bought wouldn't cover any diagnostic costs, which IMO made it unsuitable for this car.
Post #260311 Sun Mar 21 2010 7:54am
quantz
The one I'm talking of is proposed by LR dealers. 2010 TDV6 3.0 HSE Santorini Black Tan Full Leather
Post #260322 Sun Mar 21 2010 10:30am
shuzzy
I have never come across an aftermarket warranty that made me think 'that covers virtually everything and at a reasonable price'. Even Warranty Direct which is supposed to be recommended by What Car, they give you a list of parts that are covered and anything not mentioned is not covered. That probably means there are 100's of things that are not covered. I dont know how many individual parts my car consists of. I do know they wouldn't have covered my parking sensors which cost me significantly recently. I would have been furious if after spending nearly a grand on a warranty that they would not cover the cost.
Post #260346 Sun Mar 21 2010 2:00pm
rajhirani
United Kingdom 2012 Range Rover Sport SDV6 Autobiography Fuji White
all i bought a warranty for my rrs from Kam on here, the warranty is very comprehensive, and very good value for money.
there are some threads on the forum discussing the warranty.
Post #260353 Sun Mar 21 2010 5:45pm
scott7
Scotland
You can only really know how good a warranty is once you have used it.
Post #260366 Sun Mar 21 2010 7:00pm
scott7
Scotland
rajhirani wrote:
I think youll find that the warranty you've bought only covers a labour rate of up to sixty pounds, and will not cover the cost of any diagnostic work, which means if you use a land rover main dealer you will always have a bill, probably ok of you use an independent garage that has a lower labour rate.
Post #260671 Tue Mar 23 2010 7:42pm
