![]() | Home > Technical > select `access` then it raises to extended mode ?????????? |
| MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104
Bad height sensor |
| Bobby Member Since: 07 Jun 2005 Location: Kuala Lumpur Posts: 3781
What happens when you select extended mode? Malaysia Boleh!
| Bob. Member Since: 02 Feb 2009 Location: SWest Posts: 275
This has happened to me a few times - always found that it works the right way if I look at the rocker switch before pressing it though. |
| nickspark Member Since: 01 Jan 2010 Location: plymouth Posts: 12
but you cannot select extended mode anyway ..............numpty |
| Micrometer Member Since: 26 Nov 2009 Location: Cambridge Posts: 39
Its stuck. If you select access and the vehicle drops onto something then it will raise clear of said object. Could that be possible?? Trust me, i'm an Engineer! |
| Leo Member Since: 17 Sep 2007 Location: Nomad Posts: 554
Someone on disco3.co.uk had the same problem - was an electrical issue, don't remember what. |
stealer fitted new sensors and compressor........seems ok now. |
| All times are GMT |
