| RRSPORT.CO.UK | ||
|  | Home > Technical > select `access` then it raises to extended mode ?????????? |
| MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104      | Bad height sensor   | ||
|  Wed Mar 03 2010 8:54pm |
| Bobby Member Since: 07 Jun 2005 Location: Kuala Lumpur Posts: 3781      | What happens when you select extended mode? Malaysia Boleh!
|  Thu Mar 04 2010 1:28am |
| Bob. Member Since: 02 Feb 2009 Location: SWest Posts: 275    | This has happened to me a few times - always found that it works the right way if I look at the rocker switch before pressing it though. | ||
|  Thu Mar 04 2010 9:08am |
| Tim in Scotland Member Since: 30 May 2005 Location: Driving along in my automobile Posts: 17476    |
|  Thu Mar 04 2010 9:11am |
| nickspark Member Since: 01 Jan 2010 Location: plymouth Posts: 12    | but you cannot select extended mode anyway ..............numpty | ||
|  Fri Mar 05 2010 8:18pm |
| Micrometer Member Since: 26 Nov 2009 Location: Cambridge Posts: 39      | Its stuck. If you select access and the vehicle drops onto something then it will raise clear of said object. Could that be possible?? Trust me, i'm an Engineer! | ||
|  Tue Mar 09 2010 11:34am |
| Leo Member Since: 17 Sep 2007 Location: Nomad Posts: 554    | Someone on disco3.co.uk had the same problem - was an electrical issue, don't remember what. | ||
|  Tue Mar 09 2010 1:14pm |
| nickspark Member Since: 01 Jan 2010 Location: plymouth Posts: 12    | stealer fitted new sensors and compressor........seems ok now. | ||
|  Fri Mar 26 2010 7:51pm |
|  Sat Mar 27 2010 6:38am |
| Posting Rules
