Home > Maintenance & Modifications > Front grill removal
funnyguy1
United States 2009 Range Rover Sport 4.4 V8 HSE Santorini Black
Front grill removal
Is there a link that tells how to remove the front grill? Thx!! mike murphy
Post #258357 Sat Mar 06 2010 1:09am
rrs2010
If you look along the top of the grill (with the bonnet open) you will see (from memory) 4 lugs that you push down to release... Then look through the bottom of the grill there are 1 either side towards the bottom and it's off Thumbs Up Cheers Paul
2006 TDV6 HSE - Cairns Blue
Tow Pack, Privacy Glass, PTI, DVD.
Post #258360 Sat Mar 06 2010 1:26am
funnyguy1
Thank you!! mike murphy
Post #258361 Sat Mar 06 2010 4:36am
Misery
I did it so it must be easy. Embarassed Embarassed Embarassed
Post #258381 Sat Mar 06 2010 1:08pm
TB
United Kingdom 2006 Range Rover Sport TDV6 SE Arctic Frost
Yeah . . . if he did it, it really is easy.
Rolling with laughter Rolling with laughter Rolling with laughter Arctic Frost TDV6 SE. Aspen Leather, Cherry Wood, Privacy Glass, PTI, Tow Pack, Mudflaps, Tasmods, a new Fuelflap, a RRSport.co.uk umbrella in the boot & a RRSport.co.uk sticker on the rear glass.
__________________
Some people accuse me of thinking the world revolves around me, but I'm not stupid . . . I know it revolves around the sun. Which shines out of my @rse!!!
Post #258409 Sat Mar 06 2010 7:36pm
carlos50
I wanted to do this today and had no problem with the 4 tabs at the top but couldnt see the 2 at the bottom. Either they arent as obvious as suggested or i didnt look hard enough. The grill seemed pretty well secured after the 4 top tabs were released so i bottled it Embarassed
Anyone got a picture of the bottom tabs ?
Post #287428 Sun Jan 30 2011 2:36pm
SkyWalker
Netherlands 2005 Range Rover Sport TDV6 HSE Buckingham Blue
Release the 4 top tabs, then grab the grill with your hand on the lower bar in the left corner and just pull horizontaly with a little jerk, just enough for the grill to release the left lug, which is located in that area.
do the same with the right lower corner.
These lugs do not need to be unlocked first.
Be carefull not to scratch your bumper when the grill comes out!!
I always use a piece of cloth and put that between the grill and the bumper.
SW Thumbs Up SW
Sometimes it is not enough to do our best;
sometimes we must do what is required.
Adriatic Blue 2005 RRS HSE 2.7 TDV6
Now: 2016 RRS HSE DYNAMIC 3.0 TDV6
Post #287430 Sun Jan 30 2011 3:21pm
