Home > Technical > Fuel Burning Heater help |
We don't have the FFBH here but I would agree with you.
The Control Module controls and monitors operation of the FFBH. What this has got to do with the interior switches is baffling. Malaysia Boleh! 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
Wed Feb 17 2010 10:56pm |
rrsjo Member Since: 28 Nov 2006 Location: North Cambs Posts: 551 |
Thanks Bobby
Thu Feb 18 2010 12:14am |
samd Member Since: 21 Sep 2009 Location: Derbyshire Posts: 120 |
The FBH is referred to in the RRS manual under the section Heating and Ventilation and I think (memory may be wrong) that when I had a Freelander 2, the manual clearly claimed the FBH was there to improve in cabin heating for diesel engine that are slow to warm up.
Thu Feb 18 2010 10:10am |
Landlord Member Since: 26 Sep 2006 Location: Hampshire Posts: 607 |
FBH is only there to assist the engine warming when external temp is below +5 degrees. It starts automatically when vehicle is started . The knock on effect is that the cabin will heat up slightly quicker as well, when heater is on !
Thu Feb 18 2010 10:41am |
But isn't the ATC the bit that controls the internal/cabin temp? If so and ONLY IF the ATC is calling for heat will the FBH fire up? I still reckon the aim of the FBH is cabin temperature which it does by heating the engine up more quickly. |
Thu Feb 18 2010 11:14am |
All of these responses still don't answer my initial question.
Thu Feb 18 2010 12:26pm |
Sorry but I was trying to: 1. My FBH does NOT work if the heating is switched to off 2. Have checked with local LR service manager and, having confirmed with technical, agrees it should NOT work with heater in off position. 3. Why would the FBH be for anything other than cabin heating? If it was solely to heat up the engine, the only reason for that would be to save fuel (cold engine more fuel etc). Having a separate heater with its own losses of efficiency would burn more fuel than would be saved by a warm engine!! The FBH is there to improve cabin warm-up and it makes total sense that it would be heater-setting controlled and explains why fuel consumption is even higher in cold weather. |
Thu Feb 18 2010 2:22pm |
Thu Feb 18 2010 2:36pm |
I'm surprised nobody on here has taken the trouble to check this issue on their RRS? Malaysia Boleh!
Thu Feb 18 2010 11:02pm |
Bob. Member Since: 03 Feb 2009 Location: SWest Posts: 275 |
Tested my 07MY TdV8 two days running from a cold start with 1deg C ambient temperature both days. With heating switched to OFF no FBH activity.
Mon Feb 22 2010 9:05pm |
Bob, I have the same with the RRS if I want to move it off the drive to get my Defender out. This is something worth knowing from that point of view and should help cut out some extra fuel consumption and keep a green happier! Do you know if it still comes on if you press the "Prog" button on a cold morning with the other ventilation off? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Mon Feb 22 2010 9:43pm |
Bob
Tue Feb 23 2010 9:36am |
Yes Tim it does come on. I also confirmed on the 09MY TdV8 courtesy car I have that there is no FBH activity with the OFF button pressed the same as on my 07MY. If anyone wants the FBH to be used to preheat the engine, LR list a kit (part no JEC501490) under TSB LTB00027 - Cold Climate Starting Aid. This installs a Webasto timer system. Timer and phone operated installations have also been covered extensively on DISCO3.CO.UK. |
Wed Feb 24 2010 9:50am |
