![]() | Home > Technical > Fuel Burning Heater help |
| Bobby Member Since: 07 Jun 2005 Location: Kuala Lumpur Posts: 3781
We don't have the FFBH here but I would agree with you.
The Control Module controls and monitors operation of the FFBH. What this has got to do with the interior switches is baffling. 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
| rrsjo Member Since: 28 Nov 2006 Location: North Cambs Posts: 551
Thanks Bobby
| samd Member Since: 21 Sep 2009 Location: Derbyshire Posts: 126
The FBH is referred to in the RRS manual under the section Heating and Ventilation and I think (memory may be wrong) that when I had a Freelander 2, the manual clearly claimed the FBH was there to improve in cabin heating for diesel engine that are slow to warm up.
| Landlord Member Since: 26 Sep 2006 Location: Hampshire Posts: 607
FBH is only there to assist the engine warming when external temp is below +5 degrees. It starts automatically when vehicle is started . The knock on effect is that the cabin will heat up slightly quicker as well, when heater is on !
But isn't the ATC the bit that controls the internal/cabin temp? If so and ONLY IF the ATC is calling for heat will the FBH fire up? I still reckon the aim of the FBH is cabin temperature which it does by heating the engine up more quickly. |
All of these responses still don't answer my initial question.
Sorry but I was trying to: 1. My FBH does NOT work if the heating is switched to off 2. Have checked with local LR service manager and, having confirmed with technical, agrees it should NOT work with heater in off position. 3. Why would the FBH be for anything other than cabin heating? If it was solely to heat up the engine, the only reason for that would be to save fuel (cold engine more fuel etc). Having a separate heater with its own losses of efficiency would burn more fuel than would be saved by a warm engine!! The FBH is there to improve cabin warm-up and it makes total sense that it would be heater-setting controlled and explains why fuel consumption is even higher in cold weather. |
Malaysia Boleh! 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
I'm surprised nobody on here has taken the trouble to check this issue on their RRS? |
| Bob. Member Since: 02 Feb 2009 Location: SWest Posts: 275
Tested my 07MY TdV8 two days running from a cold start with 1deg C ambient temperature both days. With heating switched to OFF no FBH activity.
Bob, I have the same with the RRS if I want to move it off the drive to get my Defender out. This is something worth knowing from that point of view and should help cut out some extra fuel consumption and keep a green happier! Do you know if it still comes on if you press the "Prog" button on a cold morning with the other ventilation off? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Bob
Yes Tim it does come on. I also confirmed on the 09MY TdV8 courtesy car I have that there is no FBH activity with the OFF button pressed the same as on my 07MY. If anyone wants the FBH to be used to preheat the engine, LR list a kit (part no JEC501490) under TSB LTB00027 - Cold Climate Starting Aid. This installs a Webasto timer system. Timer and phone operated installations have also been covered extensively on DISCO3.CO.UK. |
| All times are GMT |
