Home > General > feedback invited.. cabin air temperature control
rrsboy
2010 Range Rover Sport TDV8 HSE Santorini Black
if you have a non-MY10 vehicle, can you perform the following test and provide an answer? This is to settle a dispute with a dealer "oh they all do that Sir" type scenario:
- car warmed up properly, so hot air is being expelled by the climate control
- both passenger and driver temperature control set to maximum (the red dot)
- air flow directed out of the centre (face) vents
Once you can feel hot air being expelled from the vents, please put your hand (or face) close to the drivers side window vent (the right most vent in a RHD car), and with your other hand dial the PASSENGER temperature dial a few notches LOWER.
Question - do you feel a change in temperature of the air coming out of the drivers side window vent?
thanks all
Post #253162 Mon Feb 01 2010 7:28pm
Bobby
Same problem here? Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #253209 Tue Feb 02 2010 9:59am
Lookers Park Royal
I'm with a mate on Sat/Sun who's got one, I'll check his! Wink
James Thumbs Up
Post #253226 Tue Feb 02 2010 1:06pm
rrsboy
yes Bobby, very same problem - can you tell me what happens when you perform the action on your car?
cheers
Post #253289 Tue Feb 02 2010 7:59pm
joka748
United Kingdom 2012 Range Rover Sport SDV6 HSE Alaska White
I can only detect a significant change when the passenger temp dial reaches 24 / 22 deg.
Post #253296 Tue Feb 02 2010 8:52pm
Stella Monkey
mine seem to be all over the shop .... side vents never as warm as centre vents ... overall heat blowers are not very good! ... this is not on a/c climate control though ... never used the aircon, can't afford the extra fuel !!
Post #253410 Wed Feb 03 2010 11:56am
Bobby
Average temperature here is more that 30 degrees and so will be very difficult for me to put the heater full blast and put my ear to the window! Might get burnt!! Laughing
Anyway, there is a Service Bulletin issued mid-Jan which might just address your concern..
Quote:
Models:
LA - Discovery 3
LS - Range Rover Sport
LA - Discovery 4
Title
RRS, Discovery 3/4 & LR3/4 HVAC Stepper Motor Diagnosis
Last Modified: 15-JAN-2010 08:18
Category: Electrical
Symptom: 208000 Climate Control
Concern
Should a Discovery 3/4, LR3/4 or Range Rover Sport customer report a concern with the HVAC
Air Distribution or Temperature Control operation on their vehicle, the possible cause could be
related to one of the 4 HVAC Stepper Motors, one of the internal HVAC Distribution Doors or possibly
a wiring fault.
 Malaysia Boleh!
Post #254148 Sun Feb 07 2010 10:57am
rrsboy
thanks Bobby - superstar as always! Can I ask - is that bulletin dated, and does it offer any advice for remedy/solution?
depending on the actual date, it is very likely the dealer who is trying to fobb me off with "they all do that" was actually in receipt of this exact bulletin.... Shocked
edit - just saw - 15th Jan... they had the car 23rd-30th Jan.........
Post #254258 Mon Feb 08 2010 1:40am
Bobby
Basically, when there are issues with the air distribution or temperature control, the cause could be related to one of the 4 stepper motors, one of the internal HVAC distribution doors or a wiring fault.
They will use their diagnostic tool to verify this.
Tell the dealer to check SSM43198 (1). Malaysia Boleh!
Post #254259 Mon Feb 08 2010 2:04am
