![]() | Home > Technical > Door pad removal ? how do you do it??? |
| k11ngc Member Since: 25 Nov 2009 Location: colchester Posts: 51
Passenger door pad removal??? how do you do it???
| Bobby Member Since: 07 Jun 2005 Location: Kuala Lumpur Posts: 3781
You mean the Front Door Trim Panel ? Malaysia Boleh!
CHEERS BOBBY!!! MAY ALL YOUR LOTTERY NUMBERS COME IN FOR YOU Ha Ha
Took me 3/4 of the day to retreive the blasted screw ( I did buy one from L.R. but as you can see from my pic's the hole is too small for the screwto fit through. so the power window regulater had to come out and the glass had to be released from the motor, so I could place the dam screw in it place on a metal bracket behind the key barrel, I had to take this braket out and use some masking tape and stick it there so I could put it back in and do it up from the hole on the side of the door. to put the glass back, took me a couple of hours in frezzing snowy weather. god I must like this RRS , I haven't done anything like this for 34 years since I stripped down my first american car in 1975 at the age of 18 years old a FORD MUSTANG Mach 1 1970 351ci windsor 2 barrol White/blue trim
| All times are GMT |
