Home > Technical > Washer Help
x5pea
Scotland 2010 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Washer Help
The fuse for the Window Washers went for the second time in the RRS yesyerday.
On both occasions the Mrs has been driving the car when it happened and i assumed she was at fault by burning it out pushing the button on a frosty morning, but she is adiment that she hasnt been over zelous to the extent that the fuse would pop.
Anyone experienced a similar problem? or know of a fix?
The handbook says to use a 10amp fuse im wondering if i should up the ampage.
Thanks in advance Thumbs Up
Post #245339 Mon Dec 14 2009 8:47am
lespes
Guernsey 2006 Range Rover Sport TDV6 HSE Buckingham Blue
No ideas, but must be a fault somewhere, have been reports of chaffed wiring looms .
Would not recomend bigger fuse, did that once, some years back and ended up having to stop very quickly on busy main road due to smoke pouring in the cabin from the dashboard. Big Cry
Post #245355 Mon Dec 14 2009 10:11am
Tim in Scotland
I have no idea about the blowing fuse X5, but your car is obviously suffering from the same problem as mine on these recent cold days - no washer nozzle heaters! Last night I drop back from Edinburgh down the M9 and most of the way it was -5c and thick / freezing fog. Trying to keep the screen clean was not clever. I think it's OK having supposedly heated nozzles but if the rest of the hosing back to the bottle is on the wrong side of the under bonnet insulation then the lines will still freeze up coz the engine heat isn't getting to them. Strange though that the rear screen jet never seem to freeze up on my car................................
Even Winter strength screen wash has frozen in the lines the last few mornings - maybe I need to make it even stronger
So here's a question - how do you check the washer nozzle heaters are working when you have the cold climate pack fitted? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #245366 Mon Dec 14 2009 10:46am
islider
United Kingdom 2006 Range Rover Sport TDV6 SE Java Black
Shouldn't you be able to feel the heat with your hand by touching them?
Think I may have even seen steam coming off mine. May have imagined that though?
Post #245375 Mon Dec 14 2009 11:52am
MAW
Mine used to go on the last RRS - ran out of 10's so went to 15 or maybe 20 - Thumbs Up you'll be fine at 15A
Post #245379 Mon Dec 14 2009 12:40pm
x5pea
did a 15amp top the problem mate ?
Post #245403 Mon Dec 14 2009 2:54pm
MAW
Never had to replace the 15 Thumbs Up right up to selling it on
Post #245404 Mon Dec 14 2009 3:41pm
x5pea
15 it is Thumbs Up
Post #245441 Mon Dec 14 2009 8:06pm
MikeS
Australia 2005 Range Rover Sport 4.4 V8 HSE Tangiers Orange
Which fuse is it ? I thought mine had frozen up last week, but this morning's drive to work (3 1/2hrs on the mways) was interesting without windscreen washers. Thought it odd that the headlamp washers are still working though, assumed they were fed off the same pump ?? Ex-G4 Challenge RRS HSE, BV55 YZE. Subtle shade of orange ! Now registered YZE481 G4RRS in Melbourne.
Post #249052 Mon Jan 11 2010 1:22pm
DrLex
Iceland
It's been a weak point ever since the vehicle came out, as is changing the fuse itself.The 'official' fix is uprating to 15A, as mentioned although apparently there is a technical bulletin on this, but good luck with the pincers provided!
Picture of the task that faces you:
EDIT for spelling and to add picture link
Post #249053 Mon Jan 11 2010 1:33pm
MikeS
That's exactly the fault I've got, both front and rear washers don't work. Thanks ever so for the response Thumbs Up Ex-G4 Challenge RRS HSE, BV55 YZE. Subtle shade of orange ! Now registered YZE481 G4RRS in Melbourne.
Post #249054 Mon Jan 11 2010 1:37pm
PJPR01
United States 2013 Range Rover Sport 4.4 V8 HSE Orkney Grey
I believe we had another thread on this...using a pair of long nosed pliers is much easier than the supplied red pincers. You can use them for removing as well as re-installing the fuses...piece of cake. PJPR
2017 FFRR TD6
Former LR: 2013 RRS, 2006 RRS
Post #249112 Mon Jan 11 2010 5:19pm
MAW
Nope - obviously now i guess Laughing - threw me first time also as i assumed it would be the same line Rolling Eyes
Post #249135 Mon Jan 11 2010 6:31pm
DrLex
Iceland
Agreed, but sometimes you have to make do with what you have at the time. The pincers are a pain, but better than nothing. A suitable vascular clamp or hackle plier can also be pressed into service to give the reach that the pincers lack.
Post #249177 Mon Jan 11 2010 9:29pm
MikeS
Completely different fuse box layout in my RRS, from my limited inspection in the dark last night it looks to be number 12 fuse, which was a PoP to pull out. Sadly, it didn't appear to be blown Big Cry Ex-G4 Challenge RRS HSE, BV55 YZE. Subtle shade of orange ! Now registered YZE481 G4RRS in Melbourne.
Post #249293 Tue Jan 12 2010 1:30pm
