![]() | Home > General > LIMP HOME MODE |
x5pea Member Since: 03 May 2007 Location: Lanarkshire Posts: 2097 ![]() ![]() ![]() |
haaaaaaaaaaa thats a load of poop, i wouldnt be able to pass a petrol station in mine if that was the case. If that is the prolem then there is a route cause ie a faulty sender unit, pickup, fuel pump etc etc not just "oh yeah keep your tank half full..........these Range Rovers eh!" Tell him hes a bawbag and take it to someone who has a clue ![]() |
Landlord Member Since: 26 Sep 2006 Location: Hampshire Posts: 607 ![]() ![]() ![]() |
Load of rubbish.............
It's a common problem - cure will probably be new/cleans valves. It's always the EGR valves!!!!!!!!!!!!!! 2005 Zambezi TDV6 - Gone but not forgotten
charlie Member Since: 11 Dec 2009 Location: GLASGOW Posts: 2 ![]() ![]() ![]() |
Thanks guys, suspect EGR valves might be the culprit. Have just had them done so could be faulty or botched job. Fault happened again today and engine fault flagged up briefly on display. Will investigate further. TA! |
