Home > General > LIMP HOME MODE
charlie
Scotland 2006 Range Rover Sport TDV6 HSE Java Black
LIMP HOME MODE
Sad My RRS has twice gone on to limp home mode. The car is three years old and has done 70,000 miles. Anyone else had experience of this problem? Diagnostic guy says dont let fuel go below half tank as "swill" can happen going round corners causing fuel starvation! I thought Range Rovers could go up mountains! Big Cry
Post #245127 Fri Dec 11 2009 3:08pm
x5pea
Scotland 2010 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Re: LIMP HOME MODE
haaaaaaaaaaa thats a load of poop, i wouldnt be able to pass a petrol station in mine if that was the case. If that is the prolem then there is a route cause ie a faulty sender unit, pickup, fuel pump etc etc not just "oh yeah keep your tank half full..........these Range Rovers eh!"
Tell him hes a bawbag and take it to someone who has a clue Thumbs Up
Post #245128 Fri Dec 11 2009 3:24pm
Landlord
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Alaska White
Load of rubbish.............
Have run mine emptyish up hills and over dales ! Sounds like a faulty sender. MY10 TDV6 HSE, Alaska White, Ebony with Contrast, Park Heat, Paddle Shift, Privacy, Heated Steering Wheel, Extended & Premium Leather,
MY07 TDV6 HSE, Zermatt Silver, Gone
1964 Austin Healey 3000
2007 LR Defender
2011 VW Tiguan R Line
Post #245131 Fri Dec 11 2009 3:58pm
It's a common problem - cure will probably be new/cleans valves. It's always the EGR valves!!!!!!!!!!!!!! 2005 Zambezi TDV6 - Gone but not forgotten
Post #245137 Fri Dec 11 2009 5:59pm
charlie
Thanks guys, suspect EGR valves might be the culprit. Have just had them done so could be faulty or botched job. Fault happened again today and engine fault flagged up briefly on display. Will investigate further. TA!
Post #245312 Sun Dec 13 2009 11:01pm
