| RRSPORT.CO.UK | ||
|  | Home > General > RRS 2010 and iPhone |
| Lookers Park Royal Member Since: 15 Nov 2007 Location: London Posts: 2303  | New one on me Jimmy.  Mine works fine, therfore must be an issue with the phone or the car.  You say that you have reset everything.  My suggestion would be to delete all paired devices from the phone, sync with iTunes, re pair and then see what happens.  Failing that then the nasty stealer that sold you the vehicle will need to have a look!   | ||
|  Thu Nov 19 2009 11:08am |
| Jimmy_75000 Member Since: 06 Oct 2006 Location: London, UK Posts: 1146      |
  don't be so harsh on you   I did deleted all the paired items on the phone and re paire with the car...no luck yet..When I have time, will redo a clean install of the phone firmware and will see... Thanks! Range Rover Vogue ‘17 TDV6 Gone: Range Rover Vogue '11 4.4TDV8, Range Rover Sport ‘59, Range Rover Sport ‘56 | ||
|  Thu Nov 19 2009 11:37am |
| Gazzer Member Since: 21 Oct 2005 Location: Salisbury Plain Posts: 318      | Mine is the same, seems to be about 50:50 of occasions. Seems tghe problem is with the iphone as that is the one asking whether I want the phone or car to talk.... 2010MY Land Rover Freelander 2 HSE
|  Thu Nov 19 2009 12:44pm |
 I agree with you....definitly sounds like an iphone side issue Range Rover Vogue ‘17 TDV6 Gone: Range Rover Vogue '11 4.4TDV8, Range Rover Sport ‘59, Range Rover Sport ‘56 | ||
|  Thu Nov 19 2009 1:10pm |
| umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944      | This has been reported by several owners on rr.net as well when using the 3GS version of the iPhone on AT&T's network here, so it's not just you...
|  Thu Nov 19 2009 5:54pm |
| Landlord Member Since: 26 Sep 2006 Location: Hampshire Posts: 607      | Hope the upgrade is soon. 10MY arrives 20 December and would like my 3GS to work as it should, worked ok with 07MY. MY10 TDV6 HSE, Alaska White, Ebony with Contrast, Park Heat, Paddle Shift, Privacy, Heated Steering Wheel, Extended & Premium Leather,
|  Thu Nov 19 2009 9:25pm |
| merwiz Member Since: 26 May 2009 Location: Wirral Posts: 143      | In my experience, if i use the phone to answer, i.e swipe on the touchscreen on the phone, then the phone takes the call.
|  Fri Nov 20 2009 11:07am |
| Lookers Park Royal Member Since: 15 Nov 2007 Location: London Posts: 2303  | I must admit that I've not had any issues with 2010my BT functionality with my 3Gs.  I leave the phone in my case and just use the touch screen to access the numbers and the make/answer buttons on the steering wheel.
|  Fri Nov 20 2009 3:38pm |
| Posting Rules
