![]() | Home > Maintenance & Modifications > Full Steering Lock |
Yep... annoying but normal. |
| islider Member Since: 19 Jun 2009 Location: Deepest Darkest Hedgeland Posts: 457
SM it wasn't that lamp post was it? |
SM if the RRS is in access mode then yes it's normal. If it's normal height you might have a problem. 2005 Zambezi TDV6 - Gone but not forgotten
As VA says, and I omitted.
| ELD70 Member Since: 19 Jan 2009 Location: UK Posts: 163
You need a bit of grease on the bump stops, lots of info on the D3 site with photos if you do a search. |
| Stella Monkey Member Since: 06 Oct 2009 Location: UK Posts: 48 |
thanks guys ... no it wasn't the lampost !!
| Supacat Member Since: 21 Feb 2009 Location: West Yorks Posts: 497
What's that supposed to do? |
On full lock there is a cast bump stop that the steering hits, if there is no grease on it you get a grinding noise as metal is on metal.
Had the issue ELD70 describes before, and only a couple of months and 2k milesafter being serviced.
Thanks for the extra info - I'm really struggling to visualise this - bump stops on earler vehicles would just be a touch point with an adjustable bolt and so wouldn't create a grinding noise. Anyone got a photo? |
http://www.disco3.co.uk/forum/topic40184.h...ring+stops
as I thought, it was in access mode. When reversing off my drive and steering the car it hasn't reached normal height, .... so problem solved ... thanks for the advice! |
| All times are GMT |
