Home > Technical > Transmission Fluid
Zilch
Australia 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
Transmission Fluid
Interesting chat with the local LR specialist when they serviced the Sport yesterday, they recommend changing the Automatic transmission fluid and diff oils at the next major, which will be 96K KM's. They have seen on some of the D3's that at around 80K's its looking pretty yucky, and they question the sealed for life policy or 240K KM's or 10 years that LR claim. D3 crew in ANZ seem to be also subscribing to the theory change it sooner rather than in line with the LR schedule.. seen to improve and smooth gear change etc..
Anyone heard anything similar, or looking to change before the LR subscribed date Question Its not cheap, the Automatic fluid cost $80 per litre Shocked Another Pommie Bar Steward down under
MY20 Defender 110 SE P400 Eiger/Ebony
MY10 3.0 RRS TDv6 Fuji/Ebony/Anigre
Post #238410 Tue Sep 29 2009 10:17am
2nd Rower
Australia 2008 Range Rover Sport TDV6 HSE Chawton White
I'm at only 40k km's so not yet - how many litres does it take?
Post #238437 Tue Sep 29 2009 11:43am
BKHK
I'm only at 8000km so it will be a while..... Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Post #238456 Tue Sep 29 2009 1:52pm
Martin
Site Administrator & Owner
Plenty on the DISCO3 site about changing the autobox fluid, higher mileage D3s were suffering from driveline vibration/shunting which a fluid flush sorted out.
The major cost is the fluid, which is Censored expensive, and a lot of it goes to waste during a flush Sad Like this site? Buy some RRSPORT goodies to show your support!
Post #238464 Tue Sep 29 2009 2:48pm
Zilch
Seems to make sense Martin and confirms what i heard as well, I will most probably look to change out on the next B service.. Along with the belts, ... Or maybe chop it in before then Whistle
In terms of volume i have heard everything from 5 to 9.5 litres Question
Got this off of one of the D3 posts http://www.disco3.co.uk/forum/topic30867.html?highlight=atf
Auto transmission: Shell ATF M-1375.4 Fill for life. Refer to GTR for top-up procedure (roughly 5.5 litres but ~18 litres required for 'double flush' plus sump pan inc filter - approx £65 plus ATF @ £20/litre
Going to be bl00dy expensive either way Shocked Another Pommie Bar Steward down under
Post #238538 Wed Sep 30 2009 9:52am
