Home > General > Help : Fuel Cap/Door
braddersmd
Help!
OK, I may be having what could be loosely described as a blond moment. Had the car 2 weeks now, and filled up twice - but pulled into the petrol station today, and could not open the fuel cap/door/flap thingy.
I am pretty sure that I pressed it previously, and it clicked open - or am I having a bad dream? This is not working today, and for the life of me, I cannot see a switch inside!!
All apologies in advance if this question appears to be very high on the numpty scale!!
Cheers, Mark
Post #231706 Fri Jul 24 2009 10:21am
Tim in Scotland
Mark, there used to an emergency release for it behind the small panel on righthand side of the boot panel IIRC
Try locking and unlocking the central locking a few times, that often cures things like this
I've just been out and checked my 2008MY Tdv8 and there isn't an emergency release any more! Embarassed Embarassed Embarassed 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #231707 Fri Jul 24 2009 10:24am
braddersmd
Thanks Tim,
Will give it a go shortly, and report back.
Ta, Mark
Post #231710 Fri Jul 24 2009 10:30am
If you lock the car when you get out it also locks the fuel cap - that might be the answer. 2005 Zambezi TDV6 - Gone but not forgotten
Post #231711 Fri Jul 24 2009 10:33am
Tim in Scotland
Just editied my previous post Mark - newer cars don't have an emergency release there. I'll have to go huntling for it now!
P28 of the owners manual says you have to have ALL doors unlocked to open it........................... not so I can open the flap on mine with just the driver's door unlocked and the rest locked. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #231712 Fri Jul 24 2009 10:37am
Zilch
Australia 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
had a stuck fuel flap a couple of times, i found if i pushed the flap to ensure it was properly aligned, locked and unlocked the vehicle it seemed to cure the problem, it may have not been fully closed or aligned when originally locked Another Pommie Bar Steward down under
MY20 Defender 110 SE P400 Eiger/Ebony
MY10 3.0 RRS TDv6 Fuji/Ebony/Anigre
Post #231713 Fri Jul 24 2009 10:38am
braddersmd
Hmm, just popped out to have a look at it, following a meeting. It would appear to have got itself in a tiz somehow. When I got close, the flap had somehow opened itself during my absense! Very odd - and no-one could have tampered with it, as the car is directly outside my office window, with CCTV cameras looking right at it. The car was locked.
Locked and unlocked the car a few times, and all seems well now.
Is there any way this could have got out of sync?
Cheers, Mark
Post #231731 Fri Jul 24 2009 12:31pm
You live in Leeds - that explains everything. Wink 2005 Zambezi TDV6 - Gone but not forgotten
Post #231738 Fri Jul 24 2009 1:49pm
braddersmd
Charmin. A'rl av thee know, it's reet grand up 'ere! Razz
Post #231746 Fri Jul 24 2009 2:26pm
Bobby
That's odd, Tim. I'm sure the newer cars still retain this emergency release feature.
Older cars needed only the driver's door to be opened in order for the fuel flap to be operational... .
If you need to use the restrooms or be away from the vehicle while refuelling: at the pump, close all doors and press the lock button twice on your remote. All doors will be locked but the fuel filler flap will open! Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #231804 Sat Jul 25 2009 3:07am
Lookers Park Royal
I can explain (I think Whistle )!
You probably have 'drive away locking set'? - Where the car locks at 12mph
You arrived at the fuel station and opened your door only? - Therefore the rest of the car was still locked
This meant the flap was locked
You then tried to open it by pushing it (fustration sets in at this point)
Because it was locked it wouldn't open.
Because you pused it, you released the spring catch, however the locking pin still had it locked.
When you got to your office you fully unlocked the car to get something from the rear or the boot.
Because you FULLY unlocked it you released the flap pin, so as soon as the car was unlocked the flap popped open (but only slightly).
We see this quite a bit. You just need to press the unlock button on the key or the dash to open the fuel flap. I'm only guessing that this is what happened, but you may want to repeat the above to see if this is what happened.
Doesn't sound like there is anything wrong with the car.
James Thumbs Up
Post #231806 Sat Jul 25 2009 6:36am
braddersmd
Cheers James - you may well have hit the nail square on with that one. Nothing beats experience, eh?
Noted your 5.0L has also arrived. Going on my hols today, so will check out a local one on my return.
Cheers, Mark
Post #231830 Sat Jul 25 2009 11:20am
Lookers Park Royal
Thumbs Up See you on your return..... it is a FFRR as opposed to RRS but will give you a good idea!
James Thumbs Up
Post #231832 Sat Jul 25 2009 11:40am
leedsunited
United Kingdom 2008 Range Rover Sport TDV6 HSE Java Black
Easy tiger thas no need for that Twisted Evil
Post #231939 Mon Jul 27 2009 2:00pm
MAW
James Thumbs Up
But if you take your key out the ignition all unlock do they not IIRC Question
Post #231941 Mon Jul 27 2009 2:10pm
