| RRSPORT.CO.UK | ||
|  | Home > Maintenance & Modifications > Screw in tyre |
| Very Annoyed Site Moderator Member Since: 23 Aug 2005 Location: bat-wielding monkey-spanking tough-love zero-tolerance Euro-sceptic moderator - So just watch it! Posts: 19459    |
 I have a screw firmly inserted in one of my tyres.  Is it best to:-
|  Thu Jul 16 2009 11:36am |
| Markos Member Since: 09 Dec 2007 Location: Ljubljana Posts: 187      | I also had a problem like that and the best way would be as ww told you to take it out and seal it in the way that they take out the screw and put a small piece of rubber in the inside of the tire and then press it under pressure where that rubber pcs is also heated so that it melts inside. I was told that after that kind of treatment(20-30 min) the tire is good as new. Hope it helps VA 2008 RRS TDV8 HSE, Java black, Alpaca,..... | ||
|  Thu Jul 16 2009 12:37pm |
| Tim in Scotland Member Since: 30 May 2005 Location: Driving along in my automobile Posts: 17476    | Agree with WW, but until you get unscrewed I would keep the speed down in case the screw decides to remove itself. The tyre repair folks will tell you if you need to replace or can repair the tyre. Make sure you are sitting down when they tell you how much a replacement tyres costs................................ a lot will depend on if it is in the middle of the treads or near the sidewall - if it's near the sidewall then you are looking at a new tyre 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
|  Thu Jul 16 2009 12:38pm |
| shmoogle Member Since: 07 Sep 2005 Location: ... and for every sprinkle I find, I shall kill you! Posts: 24350    | I choose 4) Something Else.  | ||
|  Thu Jul 16 2009 12:40pm |
| cyberjes Member Since: 12 Jan 2008 Location: Prague Posts: 167    | 3 and this.  just be sure not to have more than two per tire.   | ||
|  Thu Jul 16 2009 12:45pm |
| Tim in Scotland Member Since: 30 May 2005 Location: Driving along in my automobile Posts: 17476    | That kit looks like it could a lot of damage in the wrong hands............................ 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
|  Thu Jul 16 2009 12:47pm |
| cyberjes Member Since: 12 Jan 2008 Location: Prague Posts: 167    | no need to be scared actually.
|  Thu Jul 16 2009 1:07pm |
| MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104      | I'd say as per TIS's post, if it is on the 'flat' face a tyre type can repair and you can reuse. if its near the corner/wall then you'll be looking at a new tyre. You could run with it as it as long as you don't do motorway speeds and do not mind the inconvenience of the problem worsening at the most inconvenient time....
|  Thu Jul 16 2009 5:48pm |
| Tim in Scotland Member Since: 30 May 2005 Location: Driving along in my automobile Posts: 17476    | TDv8 has a cool glossy black 19" spacesaver unfortunately MAW 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
|  Thu Jul 16 2009 5:55pm |
| BKHK Member Since: 05 May 2008 Location: Perth Posts: 1942      | Anyone seen a Chinook helicopter with a screw missing?   | ||
|  Thu Jul 16 2009 8:35pm |
| will_wonka Member Since: 03 Mar 2007 Location: Tminus 12 months for the RS Sport Supercharged!! Posts: 3377    |
|  Thu Jul 16 2009 10:35pm |
| ViewWise Member Since: 13 Mar 2008 Location: London Posts: 704      | yea if its close to the edge ... new tyre. If its in the middle and you dont want to fork out for a new one a decent tyre place should be able to repair it for ~£10.
|  Fri Jul 17 2009 8:55am |
| BKHK Member Since: 05 May 2008 Location: Perth Posts: 1942      | Hmmm
|  Sat Jul 18 2009 6:25am |
| Posting Rules
 , or it might just come out and youll lose pressure quickly and probabl shred the tyre with the amount the RRS weighs.
