Home > Maintenance & Modifications > Screw in tyre
Screw in tyre
I have a screw firmly inserted in one of my tyres. Is it best to:-
1. leave it there as the pressure of the tyre doesn't seem to be going down.
2. Replace the tyre.
3. Remove the screw
4. Something else.
Thanks 2005 Zambezi TDV6 - Gone but not forgotten
Post #230959 Thu Jul 16 2009 12:36pm
will_wonka
Location: Tminus 12 months for the RS Sport Supercharged!!
Get it removed and get them to seal it (Thick Twit or such like) L322 Big Daddy SUPERCHARGED 5.0 Autobiography - Here & Now!
5 series for the miles Smile
RRS S/C factory built HST - Gone
45 others have been and gone!
Post #230962 Thu Jul 16 2009 1:01pm
Markos
Slovenia 2008 Range Rover Sport TDV8 HSE Java Black
I also had a problem like that and the best way would be as ww told you to take it out and seal it in the way that they take out the screw and put a small piece of rubber in the inside of the tire and then press it under pressure where that rubber pcs is also heated so that it melts inside. I was told that after that kind of treatment(20-30 min) the tire is good as new. Hope it helps VA 2008 RRS TDV8 HSE, Java black, Alpaca,.....
Post #230971 Thu Jul 16 2009 1:37pm
Tim in Scotland
Agree with WW, but until you get unscrewed I would keep the speed down in case the screw decides to remove itself. The tyre repair folks will tell you if you need to replace or can repair the tyre. Make sure you are sitting down when they tell you how much a replacement tyres costs................................ a lot will depend on if it is in the middle of the treads or near the sidewall - if it's near the sidewall then you are looking at a new tyre 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #230972 Thu Jul 16 2009 1:38pm
I choose 4) Something Else.
Post #230973 Thu Jul 16 2009 1:40pm
cyberjes
2008 Range Rover Sport TDV8 HSE Buckingham Blue
3 and this. just be sure not to have more than two per tire. Thumbs Up
http://cgi.ebay.co.uk/car-Tubeless-Tire-Ty...7C294%3A50 MY08 TDV8 HSE
Buckingham Blue / Ebony / Lined oak / 19" Factory / Sunroof / Roof rail / Ipod Dock
Post #230976 Thu Jul 16 2009 1:45pm
Tim in Scotland
That kit looks like it could a lot of damage in the wrong hands............................ 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #230978 Thu Jul 16 2009 1:47pm
cyberjes
no need to be scared actually.
with the wheel taken off, it's a 1 min job.
(very difficult to go wrong, imho.)
1. penetrate the puncture with the pointy one.
2. put the supplied sticky stuff through the hole in
the other tool and fold in half.
3. put the tool into the puncture and then out again.
(leave small bit left inside to do the seal.)
4. cut out the excess stiky stuff.
fyi, canned ones can get your wheel off-balance, i hear.
so i always do it the dirty way. Laughing
hope it helps. MY08 TDV8 HSE
Post #230984 Thu Jul 16 2009 2:07pm
MAW
I'd say as per TIS's post, if it is on the 'flat' face a tyre type can repair and you can reuse. if its near the corner/wall then you'll be looking at a new tyre. You could run with it as it as long as you don't do motorway speeds and do not mind the inconvenience of the problem worsening at the most inconvenient time....
From what i gain from here i'd have thought your pref on a virtually new TDV8 would be repair if poss or take the bullet of a new tyre..... Confused
Unless you can demote your damaged tyre for your spare (is it the same rim size etc...)
I wouldn't DIY fix a tyre on a £50K ish car..... Rolling Eyes
Post #231016 Thu Jul 16 2009 6:48pm
Tim in Scotland
TDv8 has a cool glossy black 19" spacesaver unfortunately MAW 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #231018 Thu Jul 16 2009 6:55pm
BKHK
Anyone seen a Chinook helicopter with a screw missing? Rolling with laughter Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Post #231024 Thu Jul 16 2009 9:35pm
will_wonka
Rolling with laughter Rolling with laughter L322 Big Daddy SUPERCHARGED 5.0 Autobiography - Here & Now!
Post #231028 Thu Jul 16 2009 11:35pm
ViewWise
yea if its close to the edge ... new tyre. If its in the middle and you dont want to fork out for a new one a decent tyre place should be able to repair it for ~£10.
I wouldnt recomend driving around with it still in the tyre since under any kind of load it may tear the tyre causing a blowout Shocked , or it might just come out and youll lose pressure quickly and probabl shred the tyre with the amount the RRS weighs. WINNER - 2008 Best All New Photograph
WINNER - 2009 Best All New Photograph
Post #231055 Fri Jul 17 2009 9:55am
BKHK
Hmmm
That will teach me to be a smart arse with VA's problem. I now have exactly the same thing only the screw is nearly out and the bloody tyre is flat and the car is in the bloody garage and its bloody Saturday aftrenoon and the tyre places are closed... Big Cry Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Post #231106 Sat Jul 18 2009 7:25am
