![]() | Home > Maintenance & Modifications > fitting brembo's |
| R33 Member Since: 14 Jun 2008 Location: Marlow Posts: 193
Yes you need the disc back plates, they are cheap any easy to get from a LR dealer. I got mine in 24hrs from CHPR. You might also need the Brembo brake wear sensor easily bought on eBay or from a dealer. Then you should be good to go. |
| kedz Member Since: 10 Apr 2009 Location: manchester Posts: 151
thank's for the info mate |
| Jonathan Member Since: 11 Jan 2008 Location: York Posts: 434
Kedz
Mine are gloss black so they look a little more bling |
Liking your gloss black idea but not going to mess with mine til they need replacing again - agree the braking is 2nd to none.
Just looked at the spec of your car for the first time and I'm a bit confused |
Yep - it has but they are the grey ones with black writing and I want RED!!!
| simonsi Member Since: 01 Dec 2006 Location: Leicester Posts: 259
They make a great D3 upgrade too..... |
| Adam RRS Member Since: 19 Nov 2008 Location: St. Albans, Hertfordshire Posts: 567
are the range rover and the range rover sport ones the same?
I´ve not compared but have seen some comments that they may be subtly different.... Cheers
Nope they are not compatible with the RRS and there are several different types for the the L322. |
also i heard if you upgrade from standard TDV6 calipers to TDV8 brembos, you need to change the hubs too. is this true? WINNER - 2009 Best in Class Range Rover Sport Award
| All times are GMT |
