| RRSPORT.CO.UK | ||
|  | Home > Maintenance & Modifications > fitting brembo's |
| R33 Member Since: 14 Jun 2008 Location: Marlow Posts: 193      | Yes you need the disc back plates, they are cheap any easy to get from a LR dealer. I got mine in 24hrs from CHPR. You might also need the Brembo brake wear sensor easily bought on eBay or from a dealer. Then you should be good to go. | ||
|  Tue May 12 2009 12:47pm |
| kedz Member Since: 10 Apr 2009 Location: manchester Posts: 151      | thank's for the info mate   | ||
|  Tue May 12 2009 9:31pm |
| Jonathan Member Since: 11 Jan 2008 Location: York Posts: 434      | Kedz
|  Wed Jun 10 2009 12:01pm |
| R33 Member Since: 14 Jun 2008 Location: Marlow Posts: 193      | Mine are gloss black so they look a little more bling   | ||
|  Wed Jun 10 2009 12:56pm |
| Jonathan Member Since: 11 Jan 2008 Location: York Posts: 434      | Liking your gloss black idea but not going to mess with mine til they need replacing again - agree the braking is 2nd to none.
|  Wed Jun 10 2009 8:47pm |
| R33 Member Since: 14 Jun 2008 Location: Marlow Posts: 193      | Just looked at the spec of your car for the first time and I'm a bit confused  | ||
|  Wed Jun 10 2009 9:49pm |
| Jonathan Member Since: 11 Jan 2008 Location: York Posts: 434      | Yep - it has but they are the grey ones with black writing and I want RED!!!
|  Fri Jun 12 2009 1:03pm |
| simonsi Member Since: 01 Dec 2006 Location: Leicester Posts: 259      | They make a great D3 upgrade too.....  | ||
|  Fri Jun 12 2009 8:04pm |
| Adam RRS Member Since: 19 Nov 2008 Location: St. Albans, Hertfordshire Posts: 567    | are the range rover and the range rover sport ones the same?
|  Fri Jun 12 2009 8:07pm |
| simonsi Member Since: 01 Dec 2006 Location: Leicester Posts: 259      | I´ve not compared but have seen some comments that they may be subtly different.... Cheers
|  Sat Jun 13 2009 7:09am |
 Nope they are not compatible with the RRS and there are several different types for the the L322. | ||
|  Sat Jun 13 2009 1:36pm |
| Adam RRS Member Since: 19 Nov 2008 Location: St. Albans, Hertfordshire Posts: 567    | also i heard if you upgrade from standard TDV6 calipers to TDV8 brembos, you need to change the hubs too. is this true? WINNER - 2009 Best in Class Range Rover Sport Award
|  Thu Jul 23 2009 9:12am |
| Posting Rules
